Better Place
Discussion in 'EV (Electric Vehicle) Discussion' started by DaveinOlyWA, Mar 19, 2009.
  1. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    David Pogue, the tech writer for the NY Times interviewing Shai Agassi, on a new way to promote EV growth
    Jump-Starting The Electric Car Dream - CBS News
    not sure i am 100% on board with the idea of switchable batteries, but he is moving forward with it and moving fast and imm, any battery is better than what we have now which is essentially NOTHING.
    **edit**
    http://www.nytimes.com/2009/03/19/technology/personaltech/19pogue-email.html?_r=1&8cir&emc=cir
    in print and much longer with more details. also touches on the hybrid idea. reading this definitely gets me more interested as the ideology behind the idea is exposed a bit more
  2. ibcs
    ibcs New Member
    351
    31
    Englewood , Ohio
    My wish list.
    Add a plug to every light pole in a parking lot. Add a meter if you want, I'd be glad to drop money for every hour of charge. Just have the ability to charge when in a parking lot.
    ---Kent
  3. daniel
    14,487
    1,519
    Spokane, WA
    With fast-charging batteries now available, and likely to become more common, battery-swapping seems to me like an idea that is obsolete before it's practical. It would require double the number of total batteries on the road, would require a high degree of standardization among manufacturers, and would be plagued by the problems of turning in a set of good batteries for a set of worn-out ones.
    I agree with the idea of plugs everywhere, with meters if need be.
  4. Zythryn
    Zythryn Senior Member
    6,408
    4,407
    The way it is supposed to work is you drive into the 'station' and the automated system swaps out your old battery for a new one. Never get out of the car, all automatic, takes 2-3 minutes (think car wash).
    IF it can work reliably I can easily see the guys doing this BECOMING the standard.
    Already plans to do this in Hawaii.
  5. qbee42
    qbee42 My other car is a boat
    18,058
    3,080
    Northern Michigan
    The swapping is supposed to be for distance driving. Around town you recharge.
    The idea of swapping makes sense for the technology at this instant. I suspect advances will quickly overtake this idea. This is the sort of field where the first guys in are going to get clobbered by rapid advances, almost to the point where it paralyzes progress. I wouldn't want to try and pick a winner.
    Tom
  6. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    the news article goes into more depth and takes the battery tech out of the EV option. iow, this eliminates the "what if i buy now and tomorrow a much better battery comes out.
    with the batteries being removable and replaceable, changing to the latest and greatest becomes much easier. as long as the standard module is large enough to contain multiple config options, the only thing needed is to match up voltage.
  7. donee
    donee New Member
    2,956
    198
    Chicagoland
    250 KW transformers are pretty common in industrial settings (according to ex-CECO engineer aquantaince). Put one out back of a your typical gas station, and you have a quick charging station.
    Do not think fast swapping will catch on.
    Standardization of the pack interconnects (electrical and cooling) and cavities in the cars to put the batterieis, and bracketry - this would be very beneficial to rapid electricification. Just like it was for rapid floppy-to-hard drive conversion in computers.
  8. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    well, i never thought fast swapping would catch on because it required a group of companies to all be on the same page. what this company has done is convinced a government to be its "guinea pig/ display model" example.
    besides the standard growth model dictates that he start with a localized grid network. build that. then build another in a different area. then provide the swap station to connect them since unlike the CIA or the "hydrogen highway" he is not stupid enough to build a road to nowhere. i think before he gets to that point, he will have either decided to go full on with the swap station or have adjusted his business model. localized charging is a much greater need right now because it addresses the current battery tech issues
    trust me, a highly successful working model over a widespread area as big as a whole country will attract major investment money
    what this guy has going is very interesting in that its way beyond the "lets talk" stage. i hope that initial reports on the progress will be available by this summer.
    now one thing i do want to clarify here... i do not expect this to be the "be all" solution in any way whatsoever. i am fully convinced that our energy needs are simply way too great for that. the energy to replace oil must come from from several different sources in several different ways to effectively overcome each sources shortcomings.
    this is looking like a great source for a significant portion of our energy needs in very large category of transportation. so cherrypick your issues. but i applaud the guy for his ability to organize and mostly for HIS ABILITY TO GET OFF HIS nice person AND DO SOMETHING
  9. rpatterman
    rpatterman Thinking Progressive
    756
    226
    Boulder, Colorado
    I agree, this is a VERY limited business plan. The expense of have auto swap hardware and multiple batteries at thousands of locations is a deal killer. Not to mention a standard battery location, size and access for millions of different cars and trucks. Might work in a very isolated location (think island) or if government mandated a "standard" design (very bad idea).
    Key words are "obsolete before it's practical".
    I think we will quickly have "smart" chargers at many locations capable of reading your battery "SPECS" and quickly re-charging while you have lunch, shop, work, pray, etc. The smart money will be developing the smart "one size fits all" charger, hooking it up to a credit card reader and selling juice at 150%-200% markup. These will be as common as venting machines. Restaurants, stores, churches and gas stations will lease them or give you the space for a percentage.
    Between overnight charging (at time-of-day rates!!!), opportunity charging and the occasional "pay-to-charge", an EV will work for everything EXCEPT the LA to NY in 36 hours mad dash. Or the long road trip to the middle of frickin nowhere.
  10. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    To be fair, the plan has a couple of upsides, even if the overall effort does not work out.
    1) It is being done by a firm that is economically motivated to do it right. Lot's of unsolvable problems are solved when the motivation is channeled to engineering solutions rather than manipulating opinion.
    2) While a battery pack is a big thing to change out, A tractor-trailer shift is done quite fast and these loads are much bigger than a battery pack. Heck, look how fast tire changes can be done at a NASCAR race. If someone were to give me a million dollars to engineer a way of changing out a battery pack automatically in under a minute, I bet I could figure out a way.
    3) The threshold for success is profitability, not universal popularity or even universal acceptance. Very few people run their house from 100% solar energy, but the inverter and solar panel market look pretty healthy to me.
  11. daniel
    14,487
    1,519
    Spokane, WA
    Tractor trailers all use basically the same kind of hitch, and many products can be loaded on a standard palate, which can be moved with a standard fork lift.
    Changing a tire is a matter of removing and replacing a set of bolts, and every Nascar team has air wrenches with the correct size ratchets for its particular car. No standardization is needed. And the team is made up of highly-motivated people well trained to do their job. And finally, the teams are very well funded by sponsors who see high value in getting their names on the cars.
    Now consider the machinery needed to automatically change out a thousand-pound battery pack in any one of a dozen different car types, each of which can have any one of 5 different battery sizes; and then install that machinery in 10,000 locations, and do it for an investment that will yield a profit at prices the public can pay. -- Compare that to the cost of intelligent chargers alone, where differences in battery specs can be addresses with a computer chip in the charger, and the only needed standardization is the plug type; and even without plug standardization it's not that big an obstacle to have several plug types on each charger.
    With today's lithium batteries, fast-charging is a much cheaper way to go than battery-switching. And if monster-value capacitors ever become a reality, all the technological problems of charging disappear.
    I wish these guys all the best, but I won't be investing my money in battery-switching. The only thing he's got going for him is he can offer the consumer a lower price on the car purchase. But the consumer will pay through the nose in the long run because not only will he have to pay inflated rates for the charge, he'll be stuck with just the one chain of charge stations: If this guy owns your battery, you cannot buy a charge from anyone else! And he needs to recoup his investment, which means you'll be paying for the battery after all.
  12. FL_Prius_Driver
    4,319
    1,527
    Tampa Bay
    I
    I made it clear that I'm not saying the concept is viable. There are many reasons it could fail and probably will. What I was saying is that many problems presented as hard and difficult sometimes have elegant solutions. This could be one of them. I worked on a farm with quite a bit of heavy equipment. Yet attaching and detaching heavy equipment designed for rapid and repeatable operation is quite easy.
    The NASCAR example was to point out something that usually takes minutes can be done in seconds. If NASCAR was motivated to make a machine do the job, then a machine would exist that could do the job.
    For example:
    1) Car pulls up to battery change station. All the battery change gear is in a pit under the car
    2) Changeout gear puts weight on battery and with one release mechanism, releases battery, lowers battery, rotates pit platform by 180 degrees and reverses the process with fresh battery.
    3) Drive off
    For all the "Equipment" needed, look at how much stuff constitutes a gas station...big tanks, lots of pumps, piping, etc. This could be less than that quite possibly
    I will fully agree that a rapid charge plug beats the living daylights out of a lot of mechanical infrastructure. I was making the point that this may not be the overwhelming showstopper imagined.
  13. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    well, i think the article DOES mention that some standardization of batteries would be necessary. a set size and the only thing variable would be how many batteries are exchanged. larger vehicles may have multiple units to replace since a smaller unit allows more flexibility in the manufacturing design. one only needs to design the vehicle using a multiple of the standard battery pack.
    look at flashlights. they all do the same thing and most use a small handful of battery sizes and options.
    either way, battery switching is by design, going to be a niche need only. EV's that do 100 miles a day will cover 94% of the average commuter's needs. throw in multiple charging stations for opportunity charging and the range is nearly doubled and now we cover 98%.
    so, swapping batteries will not be the best, most popular, nor the only option out there. so i dont think discounting what this company is trying to do based on one little facet of their business strategy is productive
  14. daniel
    14,487
    1,519
    Spokane, WA
    You left out the part about "Figure out what kind of car it is and what battery it needs and move the entire pit aparatus out of the way and move in the required aparatus.
    Okay, I agree with you that the technological hurdles could probably be overcome; and you agree with me that it's an un-economical way to solve the problem of how to get EVs charged and going again while away from home.
    Actually, you've uncovered another reason this won't work: For a 100-mile EV to make a trip across country there must be stations (fast-charge or battery-switching) every 100 miles on the road, and before anyone will buy the car there must be a network of such stations on every route they plan to drive.
    But while 100% of gas cars must fill up at gas stations 100% of the time, EVs will only be using commercial stations 6% of the time in your example. So you have a massive investment in infrastructure, where the total market is only 6% of all driving miles. The much lower investment required to install plugs everywhere makes that more practical.
    I really think that battery-switching is a solution without a problem. It solves a problem in a lead-based battery economy, but not in a lithium-based one.
  15. Fibb222
    Fibb222 New Member
    1,499
    99
    Better Place is not some fly by night operation. They have hundreds of millions of dollars of funding already (apparently some kind of record) and are well on their way to transforming Israel.
    If they say that battery swapping has a role, and is feasible, then it probably is. You can poo poo it all you want but to say new battery tech will make swapping obsolete before it even gets started is just dumb.
    We need to end our dependence on oil and coal now, not wait for more battery improvements to reach commercialization. EV technology has been sufficient for years for EVs to replace gas cars.
    Fast charging batteries are and will always be impractical. There is no way the grid will be able to supply the power for fast charging. So a fast charging, 300 mile battery, as Agassi says, "solves a problem that doesn't exist."
    For driving distance larger than 100 miles you'll need to swap. Maybe in a decade you can bump that to 150 miles before needing to swap. But better batteries will be BPs headache, not the consumers.
    What BP is committed to is that wherever one parks there should be a charging point so one can top up. They will have a quarter million charging points installed in Israel before they sign up even one customer.
    They also are committed to governments creating an open standard so other service providers of charging points/batteries and all share the same physical connections/technology.
    Renault Nissan is currently the one car company on board, but there may be others announced soon, once momentum for the Better Place network builds.
    The economics of EVs vs gas cars makes their business model a slam dunk for success. Cheaper driving/maintenance costs for the consumer and no headache as to whether they are stuck with an obselete or malfunctioning battery.
    Driving at 2 cents a mile in an EV vs 15-20 cents a mile by gas. There is lots of room for overhead and profit between those two numbers.
  16. rpatterman
    756
    226
    Boulder, Colorado
    Wouldn't the total market be 6% of al EV driving miles? Which is less than 1% of all miles driven. Hopefully to grow to 50% or more but that is quite a bit down the roads.
  17. rpatterman
    756
    226
    Boulder, Colorado
    [quote[QUOTE
  18. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    the cost will probably never be an issue. so if its 300% more, would that make a difference?? nope...still way cheaper than gas. besides, what else would you do, walk home?
    and affordable EV's start with having a batttery pack that will fill the needs (large and expensive) or providing charging stations that effectively increase the range of smaller cheaper battery packs, which makes a great temporary solution until battery tech is improved
  19. rpatterman
    756
    226
    Boulder, Colorado
    Dave,
    I might not have made myself clear. I am very supportive of EVs and BP providing charging stations (even at 300% markup). I just don't see how and where quick "swapping stations" (that's batteries!) can be profitable in the US, way too many locations would be needed with way too much inventory.
    Being able to buy the car and "lease" the battery could make EVs very affordable. Taking your EV in every couple of years to upgrade the battery pack would take the uncertainty out of the EV purchase. I can also see a secondary market for "used, last years model" battery packs.
    Would make affordable battery packs for less range intensive uses such as golf cars, NEVs, fork lifts, monster boom boxes etc. etc.
    But if I was asked to invest in a very expensive infrastructure (swapping stations) that could currently service 0% of the market share and had to compete with the gas station on every corner, I would have to pass.
  20. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    ok, i also need to clarify that i dont think swap stations are going to happen either except in very specialized circumstances. and i also think that BP's initial goal is the beehive of charging stations first. now, when covering an entire country, especially one like Australia, we are talking some major distances, ones as great as our American Plains where its not unusual to go several hundred miles and encounter nothing.
    but the real reason why i posted this is because it does not seem to be talk. we are looking at seeing results in possibly a FEW MONTHS... not a few years.
    as far as the cost, no solution is going to be cheap, and the one thing we need to know is that costs will not be extremely large for switch stations. the logistics of making sure a station does not run out of charged batteries is going to be something. what if 5 cars all pull into the same station? but, what would switch station cost??
    granted, if breaking ground on such a place, we are talking BILLIONS just for the basics. but since all these are supposed to be positioned with existing structures, i.e: existing gas stations, that lowers the cost considerably. even with that lower cost, who knows how it will work? at the rate we are making electric cars, it will take decades before we have enough on the road to support a single beehive of any size much less a national grid of anything.
    well, that is one way to look at it, and i bet in the late 50's when a single car was cruising the asphalt on the brand new I-90 in North Dakota with not a single car within 50 miles of him, the driver was probably laughing his nice person off thinking the same thing
    to be honest with ya, i thought swap stations would be for buses and semi's. personal autos would be hauled by rail then dropped off in the area they were headed if a longer trip was needed... personally i think that is a much better way to go.... the system we have now mostly just kills people, either by accidents or...
    obtw... buying the car and leasing the batteries definitely sounds like something to investigate
