Better trunk light
Discussion in 'Prius c Accessories and Modifications' started by ethan_rose, Sep 29, 2018.
  1. ethan_rose
    ethan_rose New Member
    New Zealand
    2014 Prius c
    The light in the trunk is pathetic so I bypassed the original one and put in a 10W COB LED instead wired to a barrel jack so it can be removed easily with the shelf (search for sumbulbs on AliExpress).
    Here are the results!
    DB1F497E-2F72-450C-8378-4D42F0AC3F6D.jpeg B33EC9B3-0F53-4149-B598-1F36581D495E.jpeg
    49,492
    well done!(y)
  3. dubit
    dubit Senior Member
    850
    538
    23
    Indiana
    2016 Prius c
    Very nice. If you decide to ever add an overhead light to the rear area of the car, please post that as well. Why there is no overhead light in the rear of the car I will never know, but it too is sorely needed.
  4. 4est
    4est Active Member
    207
    121
    Romania
    2013 Prius Plug-in
    Excel
    Do you mean this light?
    ztanos likes this.
  5. dubit
    dubit Senior Member
    850
    538
    23
    Indiana
    2016 Prius c
    Yes - that's exactly what the car needs. If you did that, you did a great job.
  6. Leadfoot J. McCoalroller
    7,176
    6,722
    Pennsylvania
    2018 Prius c
    Nice mod. I added silvering to the stock lamp reflector, and then a brighter LED. It helped but this removable lamp looks like a great solution.
  7. ztanos
    ztanos All-around Geek!
    3,339
    1,149
    40
    Cumming, Georgia
  8. Leadfoot J. McCoalroller
    7,176
    6,722
    Pennsylvania
    2018 Prius c
    I'm pretty sure that's a different model prius, one that already has a dome light back there. Notice the extra sail lights on the front window and the height-adjustable seat belt anchors. Cs don't have those either.
    You could put in a rear dome like that but it isn't going to look quite that good. Part of what you're looking at is a pressed, molded headliner panel with a recessed cutout to fit the lamp. You won't be able to do that as a retrofit.
    ztanos likes this.
  9. 4est
    4est Active Member
    207
    121
    Romania
    2013 Prius Plug-in
    Excel
    Yeah, I just noticed this is a prius c area. We do not have "prius c" in Europe
    Mine it's a normal prius plug in, so it has rear lights
    ztanos likes this.
  10. ztanos
    3,339
    1,149
    40
    Cumming, Georgia
    We do have a member that did this... I was just being lazy and didn't want to search. :( :)
  11. Brandon Most
    Brandon Most Member
    116
    70
    Dixon, CA
    2016 Prius c
    The Aqua shows one available . Part number crosses over to US spec 13+ Corolla, 09+ 4Runner etc. A trip to the dealer or salvage yard and you should have everything you need.
    ztanos likes this.
  12. Issy Car
    Issy Car Member
    56
    48
    Vancouver Canada
    2015 Prius c
    Thanks for the inspiration. I finally got mine done today, but I think your barrel jack turned out better than mine.
  13. AndrewsPriusC
    AndrewsPriusC New Member
    San Francisco, CA
    2016 Prius c
    Any thoughts on the DC socket being a 2-pin (pos/neg connections only) vs. 3-pin (with 3rd connection to ground of course) ?
    I want to do the same in my car, lights in the trunk. I have some DIY experience with electronics but not an academic electrical background, sadly. What I'm wondering is, with a 2-pin DC socket, the exposed part of the housing/chassis is wired to the negative terminal, so you'd always have exposed metal on your socket that's connected into the negative power line.
    I'm not super familiar with whether this might pose a safety risk in any way? vs. if a different type of connector might be more appropriate here, or at least some kind of protective cover around it ?
    #13 AndrewsPriusC, Dec 30, 2018
  14. ChapmanF
    15,619
    Car wiring typically grounds the negative side of the 12 volt system to the whole metal car body anyway. You're touching the 12 volt negative any time you're touching your car. The outside of your barrel jack poses no more of a danger.
