Beware Buyers
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Michael Flaherty, Jan 28, 2013.
Thread Status:
Not open for further replies.
  1. Michael Flaherty
    Michael Flaherty New Member
    I was told that the EV mode would use NO GAS for the 10 or so miles on short trips. It goes into gas engine mode nearly half of that time. The service writer, Nicholaus, where I bought it at Nelson Toyota in VA, told me it is working as it should, but the service technician would not come out of his office to explain, but stated on the service sheet that it stayed in EV mode exclusively the entire time. This is simply not true. I took it to Hendrick's in Concord, NC, and they came up with the same analysis, but admitted that it goes to gas nearly 1/2 the time due to the catalytic converter.
    I was deceived by the dealer when I bought it (unless they had no idea of how the plug-in works), and the follow up service at the dealership was awful. My short trips that I was told would be EV only are never as I was told, but I wasn't told the truth until I took it in for service.
    The service writer was very sympathetic and kind, but his assurance that he would follow up and be in touch with me was disingenuous too. I have heard nothing from them, which is what I expected based on what I consider outright fraud, along with the technician's denial and refusal to speak to me directly, and finally having my worst suspicions confirmed by another dealership.
    Toyota needs to come clean and make it clear to buyers that the EV plug-in is not truly or exclusively electric (in contrast to the Chevy Volt which uses no gas in EV). I was assured it was when I bought it.
  2. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    check out: the one and only prius plug in FAQ thread
    lensovet likes this.
  3. Rainking
    Rainking Member
    162
    Johnson City, New York
    Next time, do your own research first so that you know what you are buying. Do not, I repeat, do not rely on the salesmen. Ultimately, you are responsible for your purchases. There are a ton of threads here which explains what causes the ICE to fire up. Most can be avoided, some can not. I suggest you look for those thread and learn more about the car you just bought.
  4. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
  5. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    You should do your own research before making a $30k+ purchase. As far as I know, Toyota never called the Prius Plug-in an electric vehicle. It's a Plug-in Hybrid Electric Vehicle. EV and PHEV are two different things. Yes, it's disappointing that the car uses gas in EV mode. Obviously, all of us would prefer it didn't. But it clearly says in the manual as well as the brochures that EV mode is limited.
    You could've gotten a Chevy Volt so that you don't use gas in EV mode. If that was important to you, again, you should've done your own research.
    radiocycle, KK6PD and lensovet like this.
  6. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    It's too bad often salesmen and even dealerships as a whole can actually be ignorant as to how the vehicle works. So I agree as a purchaser, the onus is on the buyer to investigate and be knowledgeable as to the product.
    In Toyota's defense....it's sold, advertised and presented always as a Prius Plug In HYBRID.
    Even if it doesn't operate in the manner you were expecting, I would take a lot of solace...and actual enjoyment from the fact that you still have one of the most fuel efficient vehicles you can buy.
  7. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    There are way to burn no gas. You have to decide if it is worth altering your driving style (acceleration and speed) as well as your cabin comfort (heater, etc) to get that.
  8. bisco
    49,390
    welcome to priuschat and the pip club! who told you the ev mode would use no gas?:mad: liars! that being said, there are ways, and there are ways.:whistle:
  9. Big Dude
    Big Dude Member
    207
    76
    Wisconsin
    You guys are a little hard on the OP. Not everyone reads PC before they buy. The literature and all of the reviews--and there are many commonly say that "you can go from 10-13 mils on all electric". Had the OP bought the car in the summer, we would not have this thread. But I agree with the general sentiment--if it is overall efficiency you are looking for, you made a good purchase. For many who mix long (100+) and short trips and take an occasional road trip, the Prius can't be beat. If you just stay within a 20 mile radius and EV is paramount, then VOLT is the one. I found it too limiting for my needs. Love my prius.
    JMD, SJ PiP and kenoarto like this.
  10. bisco
    49,390
    it's NC, it is summer!:)
  11. Zythryn
    Zythryn Senior Member
    6,235
    4,231
    I am sorry you got mis-information from the sales guy. However, the EPA sticker right on the car window lists 6 miles all electric range. This is as far as the EPA testers got before the engine briefly turned on.
    The Prius is a wonderful bit of engineering. However, if your goal is to not use gas, the Volt (depending upon your driving pattern) or BEV (again depending upon your driving pattern) would have been a better choice.
    Also remember, dealers are not Toyota. You may want to contact Toyota directly. If you received any emails or written documentation stating that the PiP would not use any gas in the 11-13 mile range, that will go a long ways.
    kenoarto and lensovet like this.
  12. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    bingo.. I think many folks here have realized that, generally speaking, the sales person has no clue how the PiP works. In contrast to what you were told, others were told the PiP is "no different from a regular Prius" as well.. although I suppose that is closer to the truth.
    MPGnutcase, SJ PiP and lensovet like this.
  13. The Electric Me
    9,083
    5,798
    Not being hard on the OP.
    Salesmen should be knowledgeable and forthcoming about the operation of the product they are selling. But don't we all know that often times there is a gap between the "ideal" and the "real"? You'd hope a salesman wasn't so anxious to make a sale and/or ignorant about the how the product actually performs that they either accidentally through ignorance or purposely in a desire to make a sale, misrepresent the product, but in either case it happens.
    Therefore, I don't think there is anything else to tell the OP. Whether you are buying a box of crackers or a Plug In Prius, ultimately it's up to the purchaser to be aware of what they are purchasing.
    The FANTASTIC thing about living in this time period? And obviously having access to a computer, is I believe Prius Chat or otherwise, there is no excuse for any automobile purchaser, of any automobile, to not be very well versed on the details of the automobile they are purchasing.
    Today it's not like not so long ago, where informational resources outside of a dealership were actually pretty scarce. Today, websites like Prius Chat....or just an internet google search, will bring you more information than people were able to get in the past. Takes less than an hour, to become a pretty well versed in any vehicle.
    Personally, I wouldn't make ANY new vehicle purchase without at least visiting a few sites. MSN, Edmonds, Yahoo....all have tons of "expert" and owner reviews. In this day and age? If you can afford a new vehicle? There really is no excuse for not "knowing" about that vehicle before you purchase it.
    I'm not meaning to be hard on the OP, but I'm thinking there really isn't anything wrong with the Plug In-Hybrid they purchased.
    The post title is Buyers Beware....okay..but also...Buyers make yourself Aware....you really can't count on a salesman that perhaps isn't understanding your question, or simply really is unaware of the capabilities, or might have his or her interests above the purchasers.
  14. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,996
    Fort Lee, NJ
    What's your commute like? Distance, speed, charging pattern (at home and work?), etc.
    With tips, perhaps you can adjust a few things to make PiP work for you.
  15. Big Dude
    Big Dude Member
    207
    76
    Wisconsin
    Yeah, just trying to be a little empathetic. I've made my share of buying mistakes and when you feel like you have been snookered you alternately feel embarrassed and mad at the same time. I agree that he is venting in the wrong direction. Toyota has clean hands unless you believe that they have a responsibility to require dealer and sales person training before selling a product. This is a site to and for researchers. Not everyone shares the same passions. Still those who made the point about 32K investment are right. Yet, that does nothing to make one feel better, only worse. Truth of the matter is that he still made an excellent choice even if he is negatively surprised by this reality. He will also find many positive surprises as I did-- and I read PC beforehand!!
    mmmodem likes this.
  16. usnavystgc
    3,159
    989
    Tucson, AZ
    Well, as an interested bystander to this thread, I have to ask;
    If I buy a PIP and I want it to stay in EV only mode all the way to work (6 miles) what do I need to do (say winter driving)? Or, is this not possible?
    kenoarto likes this.
  17. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    Basically, don't put your heat on and stay out of the PWR area on the HSI.
    And by don't put your heat on, I mean don't even think of hitting auto or defrost mode because most def it'll trigger the engine.
    kenoarto, cwerdna and usnavystgc like this.
  18. 3PriusMike
    2,963
    2,314
    Silicon Valley
    It will, but only if you don't do certain things (as others have pointed out)...such as use the heat, front defroster, hard acceleration.
    I drive many days in a row with no gas at all.
    I think it is generally widely known that car salesman aren't always the best source of honest information. But you may have also tended to hear what you wanted to hear because you didn't know the "exact" right questions to ask.
    Mike
    lensovet and Blu-ray like this.
  19. usbseawolf2000
    14,487
    2,996
    Fort Lee, NJ
    You can use the electric heater in the seats without worrying about ICE triggering.
    The battery power threshold in HV mode is about 11 kW (15hp) before ICE triggering. That's how a regular Prius operates.
    Prius PHV EV mode (default) has up to 40 kW (54hp) when fully charged to about 35 kW (47hp) before entering HV mode. EV driving power is about four times (3.64) more.
    usnavystgc likes this.
  20. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    There are still salesmen out there selling the traditional Prius on the basis that you can travel upto 30 mph on electric only using no fuel. Sure you can, in a very limited number of ideal circumstances for a very short distance.
    Do your homework and take a test drive. Buyer beware, but I appreciate your feeling mislead. Car salesmen seem to have a certain reputation the world over. Isn't it a case of 30% horse ****, 30% bull **** and 40% truth?
Thread Status:
