BEWARE! Gen 3 catalytic converters are as easy to steal and Gen 2's.
Discussion in 'Gen 3 Prius Main Forum' started by Georgina Rudkus, May 2, 2021.
  1. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,468
    2,434
    Taylors, SC
    I am starting this thread to dispel that myth, as I believed earlier, that Gen 3 catalytic converters are harder to steal and not as valuable as the Generation 2's.
    Actually, Gen 3 cats are as easy to steal successfully as those of the Gen 2.:(:eek::(
    There was one individual with a Gen 3 stolen in Bellevue, WA with one clean cut, the oxygen sensor wires severed and the two bolts of the exhaust manifold removed.
    With the one clean cut at one particular place with a Sawzall and removing the two bolts, the converter just falls down by gravity just like on the Gen 2.
    Knowing where not to cut the coolant lines to the engine pre-heater means that no fluid would leak out onto the thief.
    This is not widely known, but will definitely affect theft of Gen 3 cats in the future.
    #1 Georgina Rudkus, May 2, 2021
    Grit likes this.
  2. rjparker
    rjparker Tu Humilde Sirviente
    10,164
    6,319
    Texas Hill Country
    Good thing we are making it easy to find this information.
    scona, xliderider, Merkey and 2 others like this.
  3. Georgina Rudkus
    3,468
    2,434
    Taylors, SC
    The pros know, already. It's just that there are so many Gen 2's that are not protected and readily available for easy pickings.
    I posted it as a warning to allow those who want to protect themselves before they become victims.
    Like burglar alarms, most individuals install the after they have been burglarized.
    Joonnoon19, Jim Swart and ASRDogman like this.
  4. RebL
    RebL Junior Member
    69
    Massachusetts
    Anyone out there who’s had a shield of any brand through a couple of winters where roads got salted? I am concerned that the shield will hold salt slurry against the car frame and exhaust system, which could maximize damage.
    Also, down the line, how much time will the installation add when any part covered by the shield needs work/replacement?
  5. Georgina Rudkus
    3,468
    2,434
    Taylors, SC
    I sprayed anti rust compound like this between onto the under-body rails before installing the aluminum shield. This, along with the thin factory e-coat and paint basically acts as a dielectric insulator and the steel of the under-body rails.
    I use rivet nuts to install my shield with a combination of hex and security Torx screws, and then fill them with a pliable sealant to frustrate the thief. It's tedious, but you need a time consuming procedure with a micro thin flat blade screwdriver to completely remove the filling to remove the screws.
    I do not recommend using the "stick on" foam tape that Miller Cat provides or any spacer to make a gap between the shield and the frame rails. That only collects salt and other road debris. Bending the shield downward in the center is a better method of getting more clearance to avoid rattles.
    RebL and Grit like this.
  6. tonycd
    tonycd Member
    84
    56
    This. OP's post, just like his matching one in the other thread, reads like a theft primer. I'm surprised he didn't set up a GoFundMe to publish a map of the coolant lines so it was easier for the Sawzall to avoid them.
    There, it worked. You got my attention. You win the Internet.
  7. Georgina Rudkus
    3,468
    2,434
    Taylors, SC
    The intent of this thread is a warning that catalytic converter protection for Gen 3 Prius models is needed.
    The professional thieves already know how to easily remove the Gen 3 cats.
    Even those negative posters have figured out how to do it.
    Jim Swart likes this.
  8. ETC(SS)
    7,173
    G4 cats are probably just as easy to steal as G1-3s are.....there is just not enough demand for those cats yet because the G4s are mostly young enough not to need them.
    The idea that posting the fact that G3 and G4 cats are as easy to steal impacting their rate of theft speaks for itself.
    You cannot repeal the law of supply and demand.
  9. Mendel Leisk
    41,495
    Or the 4th gen cat is harder to access? Or has even less precious metals? From what I’ve read the stolen cats are mostly being broken down and their precious metals extracted.
    fuzzy1 and Grit like this.
  10. Grit
    Grit Senior Member
    6,573
    4,227
    Wilkes Land
    sure can, the government just has to step in. Government in other countries stepped to run their AG businesses and wrecked it as history shows.
  11. AW82
    AW82 Member
    186
    99
    Madison, WI
    I mean, the US too. Look at farm subsidies and government-funded efforts to increase pork and beef consumption in the 80s and 90s along with current efforts to increase ethanol use.
    Or more directly, the roadway system, which is heavily subsidized by income and property taxes (gas taxes pay only a portion of state and interstate highway costs and none of local road costs). The more roads there are to drive on for free, the more people drive. The name for this phenomenon is "induced demand" and the federal and state governments have intentionally created a driving culture and increased demand. Ironically, efforts made to decrease driving are often called "socialist" when the US has the most socialized transportation system in the world, in which my wealth as an urbanite that drives relatively little is redistributed to rural and suburban folks that drive a lot (in the form of free-to-use rural roads, etc.).
    (Friday afternoon is a good time to hit the beehive with a stick)
    DogDaze and Grit like this.
  12. xliderider
    xliderider Senior Member
    8,140
    3,276
    Honolulu, HI
    How is this done? I read in a review on Amazon that a mechanic who installed the cat shield bent the shield using a 2x4. I assume it's done by laying the shield over the 2x4 (2x4 placed front to back, down the middle) and applying body weight to the shield on either side of the 2x4?
    I'm going to install my cat shield today.
    Also, any advice on how to get the Prius (Gen 3) high enough off the ground to use the heavy duty riveter, using only a floor jack, ramps, and jack stands? Oh, and some 4x4 lumber, if I need to place that between the jack and the car to gain extra lift. I'm shooting for at least 15 inches of clearance between the frame rails and the ground.
  13. Mendel Leisk
    41,495
    6 ton jack stands and a 3 ton floor jack with 20” or more floor to top-of-cradle?
    thinking too: if you put any amount of crease in it, will that mess up the hole loc’s? Not sure.
    xliderider likes this.
  14. xliderider
    8,140
    3,276
    Honolulu, HI
    Putting a "gentle" bend in the middle, I'm thinking more "a curve, than a crease", will not affect the four large holes at the front edge of the main shield, as there is plenty of clearance/tolerance (slop?) on those. All of the remaining mounting holes are to be drilled into the frame rails using the shield's holes as a template, so offsetting them slightly won't be a problem.
  15. Mendel Leisk
    41,495
    Something I’ve done, a little involved but works, will gain you maybe 3”:
    Raise with floor jack, as high as it’ll go.
    Settle on jack stands. (Preferably at front end of longitudinal body rails, much more solid/stable than scissor jack points.)
    Roll out the floor jack, slide in 4x4’s; make a raised cradle. Through bolts so the timbers stay together is good.
    Wrestle the floor jack atop the timber cradle, raise again, increase jack stand height.
    DogDaze and xliderider like this.
  16. xliderider
    8,140
    3,276
    Honolulu, HI
    That's what I was thinking too, using the 4x4s to raise the jack, except I might strap the 4x4 cradle together using ratcheting webbing, front and back.
  17. Mendel Leisk
    41,495
    I did sim with 2x4’s on edge; drilled holes at both ends, ran threaded rod through, nuts and washers.
  18. xliderider
    8,140
    3,276
    Honolulu, HI
    DogDaze and Mendel Leisk like this.
  19. Mendel Leisk
    41,495
    Cut a couple of sheets of 3/4” OSB too, same dims as the 2x4 cradle, and laid on top. Smoother rolling surface, and another 1.5”.
    I hardly ever need it now, is cumbersome, but something like that can gain you the extra clearance if you need it.
  20. Georgina Rudkus
    3,468
    2,434
    Taylors, SC
    After I installed mine, I just grabbed the rear end of each piece on each side of the longitudinal slot and pulled it down until I got enough clearance. It's as simple as that.
