Beware! Using the "wrong" hose clamps on radiator hoses can destroy your radiator.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Mike500, Apr 23, 2014.
  1. Mike500
    Mike500 Senior Member
    2,593
    764
    Installing the wrong aftermarket hose clamp can cost you the price of a new radiator.
    For years, I've replaced the OEM radiator hose clamps on all of my cars with worm drive stainless steel ones.
    No more! With plastic radiator necks, I only use the OEM or OER spring tensioned "Constant Tension Clamps."
    The excess pressure on the clamp under the worm screw will eventually deform and crack the hose neck.
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    Good point. I found out the hard way too on one of my kid's car.
  3. KennyGS
    KennyGS Senior Member
    1,243
    1,044
    Keystone State
    Not trying to thread jack... I just saw this in an episode of Motorweek
    The explanation about using the OEM clamp starts at 1:47.
    exstudent likes this.
  4. Mike500
    2,593
    764
    Good find...
    I first knew about using OEM clamps for the diesel VV Rabbit in the early 1980's. The service manual stated specifically, NOT to using anything than the OEM clamps.
    I soon knew why...
  5. exstudent
    exstudent Senior Member
    2,214
    901
    Torrance, CA
  6. hchu1
    hchu1 Active Member
    316
    127
    Houston, Tx.
    2014 Prius v wagon
    Yep, another tool to buy. :(
  7. Mike500
    2,593
    764
    A pair of Channelock type water pump pliers work just fine.
    The clamps I really hated were the Ford and GM wire ones with the screws that came on cars on the 1960's, 1970's and 1980's.
