Beyond economic repair. CAN YOU HELP?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by smithra, Feb 11, 2009.
  1. smithra
    smithra New Member
    london
    2001 Prius
    Hi
    I have a 2001 model Prius, which has now developed a fault.
    The car was examined by a toyota garage and I have been told that the HYDRO PUMP is faulty and should be replaced. The problem is that there is a major cost to this and the repair would not be economically viable, given the age and mileage of the vehicle.
    Is there anyone who knows more about this problem?
    Is there a prius mechanic/specialist in the UK who could offer a solution?
    Is there a possibility that the Hydro Pump could be reconditioned or repaired?
    Comments appreciated
  2. Mjolinor
    Mjolinor New Member
    229
    Greece
    2002 Prius
    Depends if it is gen 1 (97-01) or gen 2 (01-03). There is a gen 1 on eBay at the moment breaking for spares.
  3. Sofia
    Sofia New Member
    Inverness
    2001 Prius
  4. smithra
    smithra New Member
    london
    2001 Prius
  5. smithra
    smithra New Member
    london
    2001 Prius
    It's gen 1
    Problem is Toyota insiston NEW parts and other garages find it too complex to attempt a fix.
  6. halpos4
    halpos4 "Taxi"!
    377
    24
    Ireland
  7. Sofia
    Sofia New Member
    Inverness
    2001 Prius
    Can we clear up the whole gen 1, gen thing.
    My garage says that my car is gen 1, but another expert says that gen 1s are only Japanese imports. He says that imports' codes cannot be read by UK computers. Hence my car being a gen 2. But my garage is adamant that it's a gen 1.
    My expert insists their wrong and it's a common mistake to make.
    What to do?
  8. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    It's complicated.
    Most commonly we refer to the 2001-2003 as gen 1, but technically the first gen '97-'00 are the real first gen.
    If you want to, just call your car the "classic", the '97-'00 the original, some are now calling the '04-'09 the "iconic". Regardless, don't take any crap from the dealer about what you call it, it's an '01.
  9. efusco
    19,891
    1,192
    Nixa, MO
    Your dealer might not be willing to do it, but there are many qualified private garages and shade-tree mechanics that can and will...and it can save you a TON of money to do so.
  10. Patrick Wong
    18,200
    6,472
    Sofia and smithra,
    My first question is whether your cars are NHW10 or NHW11? You can identify the model number if you look at the VIN plate. Another way to differentiate the vehicles is that NHW11 has a little spoiler mounted on the trunk while NHW10 does not. A final way is that the NHW10 dash has all Japanese language markings since it was intended for the Japan domestic market.
    If your car is NHW10, then it is a JDM vehicle that was subsequently imported to your country. Should that be the case, I suggest you find the Yahoo NHW10 Prius forum and post your questions there. NHW10 is quite different from NHW11 and you'll benefit from focused experience provided by UK NHW10 owners like yourself.
    Further if your car is NHW10, then I do not believe that the diagnostic codes can be read due to an unusual protocol being used. Since that vehicle was intended for JDM only I do not believe that English-language repair documentation is available.
  11. smithra
    smithra New Member
    london
    2001 Prius
    Hi
    Thanks for your comment.
    Mine has a spoiler, so it must be NHW11
    I've had diagnostic test done and the following error code came up:
    C1521
    HYDRO BOOSTER PUMP FAULT
    How difficult would it be for a non-toyota garage to take on this fix?
    I already had one garage refuse to pursue it.
    Thanks
  12. smithra
    smithra New Member
    london
    2001 Prius
    Re: Beyond economic repair. CAN YOU HELP?
    Hi
    C1521
    I live in London, UK
    Anyone have a suggestion?
    Thanks
  13. Patrick Wong
    18,200
    6,472
    DTC C1521 is an electric power steering malfunction. It is necessary to replace the electric steering gear. I think it would be difficult for a non-Prius specialist garage to effectively repair this since specialty diagnostic equipment is required to calibrate the system. Hence I suggest that you enlist either a Toyota dealer or a Toyota independent garage that can claim a Prius specialist onsite (if such exists in your area) to make the repair.
    If you want more info about the problem, or if you have a Toyota independent garage willing to learn about repairing Prius (at your expense) then you can download repair manual info here.
    Toyota Service Information
  14. Mike Dimmick
    Mike Dimmick Active Member
    963
    247
    Reading, UK
    I think you have some digits transposed there. C1521 is an Electric Power Steering fault code. C1251 is Malfunction in Hydraulic Brake Booster Pump Motor.
    Unfortunately I only have access to 2004 and 2006 model manuals (which someone helpfully uploaded onto the Internet) and the newer car doesn't log this code. The dealer should have access to techdoc.toyota-europe.com - you can get a one-day subscription for €16.
    The most expensive fixes are likely to be replacing the brake actuator assembly or the brake control ECU. The actuator looks like a real pain on a 2004-2009 Prius as the inverter is in the way, so you have to remove it first.
  15. smithra
    smithra New Member
    london
    2001 Prius
    Hi
    Sorry
    I think the code was C1251 (typing error)
    HYDRAULIC BOOSTER PUMP MALFUNCTION
    TOYOTA can of course fix the problem, but they say the part is difficult to get hold of and will only order a new part costing in region of £900
    I would like to know if I have an alternative option.
    Thanks
  16. Patrick Wong
    18,200
    6,472
    Well, my recommendation that you seek a Toyota dealer or independent Prius specialist remains unchanged.
    DTC C1251 is a malfunction in the pump motor for the brake system. The Prius brake system is much different from a conventional vehicle, so you would not want to entrust its repair to someone not familiar with its operation.
    You previously raised the issue of using a salvage part instead of new. When it comes to the brake or steering systems which are safety-related, I think it would be unwise to use salvage parts of dubious condition.
  17. ea8631
    ea8631 Member
    186
    Toronto, Ontario
    Technology
    the parts number (for north american prius) that you need is 4707147010 (Hydraulic Brake Bosster Assembly), and I get a quote from website (website name is 1sttoyotaparts) is around $750 usd, which is around GBP$560. If you just need the pump, the parts number is 4790647010 it's USD$513.31 or GBP$362. Maybe try to ask your dealer can you bring your own parts for them and let them install for you?
  18. halpos4
    halpos4 "Taxi"!
    377
    24
    Ireland
    Hi smithra,
    I get my Genuine Toyota Parts from the UK because even with shipping from UK to Ireland it works out a hell of a lot cheaper than buying from Toyota here,send this guy a mail [email protected] and give him the part number and see what price he gives and how much the garage will charge to fit it.
