Big Prius trouble for Sister inlaw
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by B. Roberts, Jan 7, 2011.
  1. B. Roberts
    B. Roberts Hypah Milah! Ayuh.
    691
    211
    used to be "Glacial" Maine and now FL
    My sister in law went to start her Prius and all the lights came on and it won't start. Now she is trying to get a tow truck to take her car to the dealer, but she's parked head in at a small business building. It's in park... with IG on can the trans be put into neutral?
    Help!!
    Thanks
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Only if it is Ready mode I believe. What model year is it?
  3. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    Spidey,
    +1
    You thinkin' like I'm thinkin' that the pesky
    12V battery gremlin
    is sneakin' round under the hatch area floor?
  4. B. Roberts
    691
    211
    Her Prius is an 06, just hit 50K miles (Florida car). The tow truck operator jumped the small battery... using the proper method under the hood... and got the car into neutral.
    We have a 05 (Maine car), it's still on the original battery, and it's just above 94k miles. We are considering a new battery for it, before the one we have fails.
    What battery Gremlins lurk back there in that little battery compartment?
  5. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    All too often,the 12V battery is a source of frequent complaints as it
    approaches/passes it's typical 4 yr. service life. Reductions occur when
    it is subjected to extremes of either heat -- Florida, parked in the open?
    -- or cold. Also, having to "jump start" the car, typically due leaving an
    interior light on, is usually the first step on the slippery slope to the
    12V battery slowly dying, unappreciated, in the lonely dark uner the
    floor boards.
    When all is well with the 12V battery, its most important function is to
    boot the CPUs when the car is in READY, which then leads to the HV
    battery circuit breakers closing... vroom, vroom and off we go!
    Should the 12V battery get seriously discharged, as a point of reference
    ~12.0V, all manner of strange/annoying/enraging things can happen.
    In no particular order;
    "Christmas Tree" warning light dash display
    Car won't start
    Car won't turn off !!!
    Random, intermittent horn and/or wipers
    Severely reduced MPGs
    etc.
    Those are the gremlins, lurking, leering, way in the back.
    :D
  6. B. Roberts
    691
    211
    Thanks, all. She did mention the "Christmas Tree" dash lights.
    OPTIMA still the battery of choice for us?
  7. bisco
    49,694
    get a price from your dealer on an original and compare it to the time, trouble and cost of the optima.
  8. SageBrush
    SageBrush Senior Member
    11,627
    2,531
    Southwest Colorado
    I went the optima route last year, but next time I'm going to buy Toyota OEM and intstall it myself.
  9. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    Why?
    We anticipate needing to change ours out in the next year, and had thought that the Optima was a better battery than OEM.
    Please share your experience.
  10. rpeeples
    rpeeples Experienced Toyota Owner
    109
    America's own third-world country
    Just wondering if there is an explanation somewhere of how a low battery can affect MPGs? Not disputing it or anything, just curious....
  11. SageBrush
    11,627
    2,531
    Southwest Colorado
    Hi Rae:
    Optima + shipping + adapter is not much cheaper than the OEM, so long as you do not let the stealership install. I got five good years out of my original battery and actually only replaced it somewhat preventively, so I am unconvinced a quality difference exists between the two choices.
  12. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
  13. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi All,
    The Optima battery is available at Advance Auto Parts. Be sure to check the manufacture date. So, once you have the Elearnaid adapter kit installed, its pretty quick to replace....
  14. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,512
    38
    Santa Fe, NM
    Dead battery horror stories abound here on this forum with regards to the OEM battery. This is one reason that people have been charged thousands when their IC pump fails, because after a short time of driving the car, the 12V voltage drops to the point that the computers get confused, and all kinds of spurious trouble codes get set.
    Nary a peep about Optima battery failures.
    Optima is a deep cycle battery, and the Prius application is perfect -- very low current draw to start the car, parasitic drains when the car is off. OEM is basically a motorcycle cranking battery, not designed for deep discharge.
    Optima requires a little more time, a little more trouble, MAYBE a little extra money. It's definitely worth it in my opinion. I have no financial interest in elearnaid.com
  15. dogfriend
    7,512
    1,188
    Carmichael, CA
    Yes, in IG-On you should be able to select N. But if you apply jumper power to get IG-On, you should be able to get Ready just as easily.
  16. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    Like stated above, the Optima is a deep cycle Battery so deep discharges will not harm it as much as it would a standard battery. This is the reason we use them in high-powered car audio systems and portable electric fencing for livestock.
  17. B. Roberts
    691
    211
    A weak battery takes more juice to maintain, so electrical generation has to take place more often, thus lowering gas mileage. Instead of producing miles, you are producing electricity to charge your underachieving battery.
