Big Red Triangle and Hybrid Warning Light
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by mjf777, Jul 25, 2016.
  1. mjf777
    mjf777 Junior Member
    Encinitas, CA
    Hey everyone,
    The last few weeks I've been noticing that, upon start, the hybrid battery is showing at 1 line. It's been really hot in SO cal and the air con has been blasting, so I've been letting it charge up a bit before driving. Once I'm on the road, the battery charges fine and seems to hold a charge.
    However,today I forgot to let it charge up and got the giant triangle of death and the hybrid warning light on the main console.
    In hunting through the forums it looks like it may be the 12V battery. I did the diagnostic check on the battery current and it was around 11.8V on READY.
    Wondering if this is the issue, or the inverter, or (least wanted) the hybrid battery going out.
    Any thoughts on next steps.
    HUGE thanks.
  2. fotomoto
    fotomoto Senior Member
    5,602
    3,778
    So. Texas
    The warning lights have thrown OBD trouble codes. Get them read via the OBD port under the dash below the steering wheel and you'll know where you stand.
    Major auto parts stores will read them for free but usually can't see all hybrid specific codes like a Toyota or hybrid specialist can.
  3. mjf777
    Encinitas, CA
    Thanks for the quick response. Will track one down and see what I get. Cheers.
  4. Patrick Wong
    18,200
    6,472
    If the car is READY when you are measuring 11.8V, then the DC/DC converter is not working. The usual reason for that is the inverter coolant pump has failed. Look for turbulence in the coolant reservoir which shows the pump is working.
    If the voltage measurement is OK when the car is cold, then the inverter itself is still OK.
  5. mjf777
    Encinitas, CA
    Thanks Patrick! Super helpful. Will be checking the codes and will check the pump in the morning.
    Cheers.
  6. orenji
    orenji Senior Member
    5,884
    3,486
    My 2010 with 60K miles just threw the ABS light and VSC light, only have had the car for a month, also noticed when the warning lights come on the and I brake, the recharge bar is only showing one bar even at full stop. The warrning lights come on for a while then will shut off. I have no idea when the 12 volt was replaced if ever. I am thinking its the 12V, does that sound right?
  7. JC91006
    16,482
    8,398
    There's a recall on 2010 brakes
  8. orenji
    5,884
    3,486
    Thanks, I purchased it from a Toyota Dealer, I would think they would have preformed all the latest recalls?
  9. JC91006
    16,482
    8,398
    I would just bring it back
  10. orenji
    5,884
    3,486
    Yeah, that would be the easy way of doing it....:)
  11. andrewclaus
    andrewclaus Active Member
    993
    324
    Golden, CO
    The ABS issue is a "warranty enhancement," rather than a recall. Look at the concurrent thread here to get a copy of the letter if you didn't get yours in the mail.
