Big trip Friday...I think I did everything I could...
Discussion in 'Gen 2 Prius Fuel Economy' started by FrankD, Mar 10, 2010.
  1. FrankD
    FrankD Member
    199
    40
    Leesburg Fl.
    Hello all.
    We leave to go back down from NY to our Florida home in Leesburg early Friday morning.
    My 2007 Prius is all clean, and I believe ready to go. It has exactly 58,000 miles on it.
    I did the following;
    1) All waxed, vacuumed, with windows spotless, etc.
    2) Michelin Harmony tires are good, with the front 43.5 psi and the rear ones are 41 psi.
    3) Checked the air filter, (clean) and cleaned the MAF sensor with the correct spray. It did not look dirty, but it was easy.
    4) Changed the oil filter and oil with new synthetic 5w-30.
    5) Checked the wheel bearings and wheels for any drag. All good.
    6) Installed a new Optima battery on Christmas day.
    7) Checked the cabin air filter. Good.
    8) All lights are working well.
    9) Took off my front vent foam blockers- will not need them anymore this year.
    I am hoping to get some good gas mileage this time, I've been struggling with low, (like under 43 mpg's all winter).
    I do not expect great mpg on the trip itself, because when driving I-95 down the east coast, I seem to go fast. I usually drive about 9mph over the limit. Sometimes that is slower then normal traffic.
    Hey, if I get stopped, I could blame the gas pedal....right??:cool::rolleyes: (Just kidding)
    Is there anything I'm forgetting?
    Thanks again for all of your good help. I love my Prius, but wish it got better mpg...I'd wet my pants if I ever hit 50 mpg in normal, non trip driving.
    I am getting tired of friends being worried about us because we own one of those "death cars"....:rolleyes::mad:.....kind of putting a damper on my "Joy of Prius" feeling.
    Frank D.
  2. ETP
    ETP 2021 Prime(Limit),24 Venza Limit,B52-D,G,F,H
    2,801
    1,170
    Auburdale FL
    Put two fat women in the back seat so it won't run away on you!:lol::lol:
  3. FrankD
    FrankD Member
    199
    40
    Leesburg Fl.
    Well, we made it fine......as I knew we would. I avg'ed only 41.5 mpg, but it rained almost all the way to South Carolina, almost 900 miles.
    Also, traffic was heavy and the flow was about 10mph over the speed limit, so some of the time I was doing about 80-82 mph....probably averaging over 70 mph.
    I now must drive daily to Tampa and back, so we will see how those daily drives will be.
    Thanks, Frank
  4. PriusLewis
    PriusLewis Management Scientist
    1,002
    84
    Denver Metro
    Glad to hear the trip went well. That mileage is about what I get from Colorado to Oklahoma. It will be interesting to see how much better it gets on the commute. Good luck!
  5. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    Drop your speed. You'll average 50mpg at 80mph only on the downside of a mountain.
  6. patsparks
    10,664
    567
    Adelaide South Australia
    80+ mph, sounds like you had some unexpected acceleration there mate. :)
  7. Prius 07
    Prius 07 Member
    715
    Toronto, Canada
    Glad you made it back safely Frank; you were well prepared. If you can drop the speed and watch your mpg rise:)
  8. FrankD
    FrankD Member
    199
    40
    Leesburg Fl.
    Well guys,
    I've been in Florida for two weeks now, driving from Leesburg to Tampa and back. It is 85 miles each way, and most of that is driving about 80 mph to keep up in heavy traffic, then less when getting closer to Tampa. The total mileage for the two weeks was 1640 miles.
    I averaged 44.1 mpg.
    I reset things, and now I will see how things are for normal, slower, around town Florida driving.
    Thanks! Frank
  9. Rest
    Rest Active Member
    1,210
    53
    CA
    I would have put more air in the tires, to help increase the mpg.
  10. FrankD
    FrankD Member
    199
    40
    Leesburg Fl.
    Really? I thought that 43.5 in the front and 41 in the rear was high, especially when driving hundreds of miles in one day......what is the optimum tire pressure then for good mpg without hurting the tires?
    Frank
  11. tam85
    tam85 New Member
    16
    illinois
    I
    nice info.. thanks..
  12. TampaPrius.com
    TampaPrius.com Active Member
    461
    296
    Tampa, Florida
    That is plenty of air especially at 80 MPH and 90 degree Florida heat.
