Bike pump with prius C
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Jon Swenson Tellekson, Dec 23, 2017.
  1. Jon Swenson Tellekson
    Jon Swenson Tellekson Junior Member
    2014 Prius c
    I
    I've always been able to pump up my tires with a bike pump on the gen 2 prius, but the C has ridiculous hubs that make this impossible. Has anyone come up with a solution?
  2. fuzzy1
    10,172
    Could you elaborate for those of us without a 'c'? How do the hubs make bike pump use impossible without doing the same for other air compressors?
    I'm presuming that you mean a typical floor pump, not the smaller frame or hand pumps.
  3. dubit
    dubit Senior Member
    850
    538
    23
    Indiana
    2016 Prius c
    Takes less than 3 seconds to pop off the hubcap. 5 seconds to put it back on. I don't see the problem.
  4. Jon Swenson Tellekson
    2014 Prius c
    I
    Good idea, but typically I think of it as I'm about to drive to work, and don't have time to wash up. Plus it's cold here in MN.
    Yes, I mean a floor pump. Problem with the hub caps is the small hole and angles prevent attaching the clamp. I should have posted a picture.
  5. Mendel Leisk
    38,735
    I use a floor-standing bicycle pump too, but don't have wheel covers, feel your pain. Ideas:
    1. Just remove the covers and add centre caps.
    2. Use gas station compressors. (Up here Chevron is still free, kudos for that.)
    3. Look into a small air compressor with narrow style tire inflator.
  6. Jon Swenson Tellekson
    2014 Prius c
    I
    Valve stem doesn't stick out far enough to clear the black rim with pump.
  7. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,482
    Bay Area, California
    2019 Prius Prime
    Carry a pair of gloves(n)?
    #7 Raytheeagle, Dec 24, 2017
  8. Mendel Leisk
    38,735
    This looks kinda interesting:
  9. Dxta
    Dxta Senior Member
    1,932
    767
    Lagos
  10. Mendel Leisk
    38,735
    You can just roll in and use the air hose, no problem there. They're my favourite station for fill up though, rarely use anything else.
    Most of the other stations you have to feed dollar coins into the pump I think? It's been years, virtually never had to do this. Actually most of the time I'm using my aforementioned bicycle pump, much simpler/accessible.
    This is in Canada though, not sure about the States. Lagos, are there Chevron?
    Raytheeagle likes this.
  11. ztanos
    ztanos All-around Geek!
    3,339
    1,149
    40
    Cumming, Georgia
    We have Chevron down in Georgia, don't know if they have free air or not. I use Kroger, which has free air.
  12. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    Free air is becoming hard to find these days in the US but most "fast lube" places will be happy to let you "air up" if they aren't too busy.
    Valve stem extensions could the the answer to your stated problem.
    Or just leave the hubcaps off.
    Or put on mag wheels.
    (y)
    KennyGS likes this.
  13. KennyGS
    KennyGS Senior Member
    1,243
    1,044
    Keystone State
    ^ This! ^
  14. Jon Swenson Tellekson
    2014 Prius c
    I
    That's what I'll do. Perfect.
    $5.49 for 4 at my local bike shop. I think I'll just keep one with my tire gauge.
    Thanks, all.
  15. Sam Spade
    2,036
    1,023
    2017 Prius c
    Now, one word of caution:
    Depending on what kind of extensions you get........if they don't have a screw on cap like a normal valve stem but instead you just force the air through ........IF in the winter time the roads are wet and slushy and you drive through some DEEP puddles, those stems with no caps can take on water. If you then leave it sit out and it turns REAL cold overnight, the water can freeze inside the extensions and cause the schrader valve to leak.
    Yep, happened to me. 3 of 4 tires flat. No more cheap extensions for me.
    Well not likely to happen again where I live now anyway.
  16. ztanos
    3,339
    1,149
    40
    Cumming, Georgia
    I think he was saying he was going to buy one and use it when he needs to put air in. But this is still great advice for the cheap extensions.
  17. trojanrabbit
    trojanrabbit New Member
    24
    Millis, MA
    2016 Prius c
    Valve extensions sound like a good idea. I've already fumble-dropped the valve covers a couple of times so I have to move the car to retrieve the cover.
    As a BJ's member (warehouse club), I can get free air at stores that sell gas (like the one closest to me). Unfortunately they don't sell Top Tier gas so I only use them occasionally.
  18. Sam Spade
    2,036
    1,023
    2017 Prius c
    In most areas of the country, "top tier" gas doesn't really exist.......as all the stations use the same base stock from the same tank farm terminal. Giving it a dose of Techron every 3 months or so will accomplish about the same thing.
    trojanrabbit and ztanos like this.
  19. jscoot
    jscoot Junior Member
    25
    23
    PDX
    Also consider your local tire shop. Mine will top up when requested, no charge. Of course, I do buy tires there, so it’s worthwhile for them.
