Bike rack mistake?
Discussion in 'Gen 3 Prius Main Forum' started by scottwyden, Sep 27, 2009.
  1. scottwyden
    scottwyden new jersey photographer
    342
    New Jersey
    I purchased a complete Yakima system for my 2010 Prius (see pics)
    However, should I have just got a trunk system? I'm never going to attach anything else to the rack other then 2 bikes.
    Did I make the wrong choice?
    I'm thinking I did.
  2. rcsting
    rcsting Toyota Fanatic
    282
    111
    Gold River , California
    A friend of mine installed the roof rack on his Gen 2. He told me that the wind noise was so annoying that he returned it and went to a trunk rack.
  3. scottwyden
    342
    New Jersey
    It's too late for me to return it.. I'd have to sell it to someone.. but I have no wind noise because of the fairing. My MPG also dropped by a few so that's not a problem either. It's just the fact that I now have this crazy strong rack intended to hold A LOT of stuff and I would only have the bikes
  4. RadioZero
    RadioZero Member
    154
    59
    Orlando
    2018 Prius
    i went with a hitch mounted 2 bike rack, Saris Thelma model. easy to take off and on. there are several bike rack threads most have pictures. check them out and make your own decision.
    they all cause our cars to take a mpg hit.
  5. scottwyden
    342
    New Jersey
    I don't mind the slight drop in MPG as I stated above.. I just think I made a bad choice because the rack is designed to carry a lot of stuff and I'm only going to have 2 bikes
  6. oldtown
    oldtown New Member
    31
    Using a roof rack can be a little easier on your bike wrt road spray, the rear end bike racks do end up giving you more "gunk" on your bike and drivetrain in poor weather. The rear does protect from bug splats, but using a bike "bra" will help a top mounted bike. Roof racks tend to protect the bikes paint job better. So, if you bike is precious, perhaps the roof is a better place. When you carry your bike up there, you will pay a bigger mpg negative, especially on the interstate or at above 40 mph.
    If you are not going to encounter rain or salt spray very often, then the rear rack idea is okay, but you need to be careful when loading to make sure you don't have your bike's frame paint in a vulnerable position with respect to some other bike's pedal, etc. It is almost inevitable that you will scratch something somewhere along the line. Mpg doesn't seem to take as big a hit with a rear mounted rack. If you are very short, then it might be considerably more convenient to use a rear rack.
    I would think about how I drive, where I go, how fussy am I about my bike, and how convenient is the roof rack. I would also think about am I going to ever canoe or kayak, do I ski, and am I a fixer upper who might need to carry wood or pipes or ladders? A roof rack is pretty versatile.
    I actually use both depending upon many things and have even carried 6 bicycles at once to some races. People stare a lot, ha-ha.
    For up to two bikes on short trips, I put them inside the Prius with the seat down and a large pillow with a thick bedspread over the bottom bike for protection. Best mpg and security. A little inconvenient with more than 1 passenger, though.
    2 people like this.
  7. scottwyden
    342
    New Jersey
    Thanks for your input!
  8. warrior
    warrior New Member
    141
    Paso Robles, CA USA
    I read that roof mounted rack increases wind drag.
  9. scottwyden
    342
    New Jersey
    It really hasn't been that bad with the roof rack (without bikes on top)
  10. regentofthesun
    regentofthesun New Member
    34
    Houston
    Scott - Don't you have the solar roof? I remembered seeing the pictures of your new baby and was going to ask you about the rack. Then I remembered that I thought you also had the solar roof and was wondering if the rack+bikes might cause unnecessary stress to the solar unit? Was this a concern?
  11. GreenWithEnvy
    GreenWithEnvy New Member
    81
    SE Wisconsin
    We have a trailer hitch rack for my husband's Yukon, and it's not the nice swing-out kind. So we have to load everything in the back first, and then the bikes on the rack, and really can't load anything after that except a few small things thru the window. So based on that I would prefer a roof rack for the Prius. However, with the Yukon we'd need a ladder to get the bikes on the roof.
  12. scottwyden
    342
    New Jersey
    I don't hav a solar. The dealers couldn't find it for me so I went with just the NAV package.
  13. scottwyden
    342
    New Jersey
    I decided to sell it and go with a trunk rack once either Yakima or Saris have one that they say fits (not one that others say fit)
    I posted it in Private sales. I'm selling it for much cheaper than what I purchased it for!
  14. darelldd
    6,057
    388
    Northern CA
    Scott -
    I'm afraid that I don't understand your reasoning at all. Let me start by saying that I carry my bikes four different ways depending on the situation. On top of the car, on the rear of the car, on a trailer or inside. They ALL have advantages. If your only concerns that your roof rack is stronger than it needs to be, then you have no concerns. Would you feel better if the rack were lower quality or less heavy duty? The Yakima racks are not *intended* for more weight than two bikes, it is just that they're capable of more weight. Just like buying a Prius and driving it solo, or with only two people and no cargo, etc. The yakima racks work great, and if you want the bikes on the roof, it does keep them out of harms way of *other* vehicles, and it keeps them out of the way of the hatch (a real PITA sometimes to have the bikes back there when you need access to the cargo area).
    Yakima and Saris have both made hitch-mounted racks that'll fit a Prius-mounted hitch for many, many years. So by "trunk rack" you must mean one that sits on the rear of the car directly - thus making the hatch even harder to get into? You may want to re-think your decision. Again, if the main concern here is that the roof rack is "too strong" or something, then you should not be concerned!
  15. scottwyden
    342
    New Jersey
    Thanks for your input Darell. It's not that it's too strong. It's that that is also intended for cargo carriers, kayaks, etc.. I'd rather simplify. I rushed into the rack without thinking it over because I got a great deal.
  16. eglmainz
    eglmainz New Member
    887
    141
    Chicagoland, IL
    How good of a deal did you get? How good of a deal are you hoping to get if you sell it? (I may be interested if I can get an even better deal?)
  17. scottwyden
    342
    New Jersey
    I paid just over $350 for the rack (with locks and all) and $140 for the kind cobra
    I want to get $350 for the rack and $125 for the king cobra
  18. blase
    blase New Member
    23
    NE Ohio
    I had the 1.25" hitch receiver mounted on my 2010 IV and bought the Saris T-Rax fold down model for $159. Works great. I thought about a roof rack but about 6 years ago I drove into my garage with a $3600 bicycle on a roof rack. Amazingly the bike wasn't damaged but the rack and the roof of the car were. But I figured if I got a roof rack it was only a matter of time before I did it again.
  19. scottwyden
    342
    New Jersey
    I would do the hitch kind but I have no need for the hitch other then that so I figure stick with the trunk mount. Anyway. Thanks for the input everyone!
    If anyone is interested in the roof rack let me know!
  20. darelldd
    6,057
    388
    Northern CA
    Hmmm.change my answer then. The racks are not *intended* for anything. They *can* be used for many things. Many thousands of people use them for NOTHING but bicycles. Many thousand others use them for NOTHING but kayaks... or cargo boxes, or ladders...
    Just like some people buy a Prius because it is a good commute car, and use it for nothing else. Some people buy it for a family car, etc. I'm not sure what you bought the Prius for, but you can be assured that it works well for other uses too, and I hope you aren't going to sell it because it is otherwise useful!
    Maybe I'm not making my point well enough. But if the Yak racks work well as a bike rack - and I know from experience that they do, and I understand the benefits and detractions... then I'm still not sure why you'd want to sell them just because the racks can also be used for cargo boxes, or lumber or... whatever. Fact is, you may find that you want to bring a few 2x4's home from the hardware store one day, and you'll be set. You can even do it WITH your bicycles up there.
    But anyway... I'll stop pounding on you now. I was just having trouble with your logic.
