Bike rack
Discussion in 'Gen 4 Prius Accessories and Modifications' started by rosencrantz, Oct 24, 2018.
  1. rosencrantz
    rosencrantz Member
    97
    77
    Central Valley, CA
    2018 Prius
    I’m thinking about putting a receiver hitch on my 2018 Prius for use as an occasional bike rack. I have a couple of questions - any suggestions as to where I can get a quality installation done? And two, should I expect a hit on the MPGs, and if so, how much? Thanks, Rosencrantz.
  2. rosencrantz
    rosencrantz Member
    97
    77
    Central Valley, CA
    2018 Prius
    Opps .... not sure how this happened.... title should read “Bike rack”
  3. alanclarkeau
    alanclarkeau Senior Member
    7,044
    7,584
    near Brisbane, Australia
    What country are you in?
  4. rosencrantz
    rosencrantz Member
    97
    77
    Central Valley, CA
    2018 Prius
    I’m in California, US. I suppose I should add... I’m asking about the potential MPG hit as a result of the receiver install. I’m pretty sure MPGs will be affected with bikes loaded.;)
  5. alanclarkeau
    7,044
    7,584
  6. rosencrantz
    rosencrantz Member
    97
    77
    Central Valley, CA
    2018 Prius
  7. Kurzweil
    Kurzweil Member
    109
    34
    Atlanta
    I had a two-inch receiver hitch on my '04. You can barely make it out on the avatar. I don't believe that it ever affected the economy. It did not disturb the airflow and was not significantly heavy, the two things that make a difference. I actually used it once to pull an empty trailer home but it was installed by the PO for your same purpose, bike rack.
