Biting the battery bullet
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by John Traynor, Aug 2, 2024 at 3:46 PM.
  1. John Traynor
    John Traynor Junior Member
    [​IMG] 2012 Prius v with 144,000 miles.
    Never had a P0A80 until now. This week I went through a carwash in neutral with the AC on & I came out with lots of errors including P0A80
    I bought the Dr Prius app and got a 33.9% on battery life so it looks like I have a new battery in my future.
    How long can I drive on a 33.9%?
    #1 John Traynor, Aug 2, 2024 at 3:46 PM
  2. rjparker
    rjparker Tu Humilde Sirviente
    8,026
    4,758
    Texas Hill Country
    The first thing is the Dr Prius calc is a guess rather than an accurate view of capacity remaining. Especially coming off a deep discharge which can result in a different guess after further driving.
    But regardless you will appreciate the increased mpg and pep a new battery will give. Be smart and buy an oem unless you just want to flip the car.
    Brian1954 likes this.
    49,567
    Try driving around for awhile and see if the code comes back
  4. Brian1954
    Brian1954 Active Member
    884
    324
    South Central PA, USA
    Are you a DIY person who feels comfortable working on the high voltage battery?
    If so, a grid charger and discharge will greatly extend the life of your battery. See this very long thread:https://priuschat.com/index.php?posts/3434610
    If not, you could try to find someone to do the grid charging and discharging for you.
    OR you could just ignore this post and buy a new OEM HV battery.
  5. John Traynor
    Thanks. We’ve done 2 days (40 miles) of driving since I did the car wash drain. I’ve seen the battery go low and driven in B to charge it back up. I thought that the deep drain had worn off. Thoughts?
    I’m pretty comfortable with tools but certainly not a mechanic. Also I can carry my 50 pound dog but not thrilled about a 100 pound battery block.
    We plan to drive this car into the ground and we drive New Orleans to New York City round trip twice per year. My biggest fear is getting stranded at the mercy of some dealership.
  6. John Traynor
    It hasn’t. In 2 days.
  7. John Traynor
    Thanks. We plan on driving this car into the ground, and the discharging is outside my skill set and might or might not work.
    I just did sway bar links, a new coolant reservoir, a water pump and head gasket job (thank god the engine and cylinders are still good) so I feel like I’m committed. I don’t think the OEM battery would be throwing good money after bad.
    It will take 2 weeks to get the battery in because they are back ordered and no one is discounting.
    If the car suddenly improves, I will have a new really expensive iPhone charger.
