Black Front Grill (Not Silver)
Discussion in 'Gen 5 Prius Accessories and Modifications' started by ORWolf, Oct 30, 2024.
  1. ORWolf
    ORWolf New Member
    Oregon
    2024 Prius
    Limited AWD-e
    I purchased a 2024 Prius Limited AWD a month ago. It is a great little car. I love everything about the car’s looks….. except the front grill. My entire car is red and black - except for the front grill and the hood emblem. The hood emblem is easy to turn black. The grill is not. Do any of you know of an available black front grill surround? I thought about just painting it, but it will definitely get rock chips which will then show the silver underneath - a black plastic molded piece would be better and it won’t show rock chips. I also have found that gen5composites offers a beautiful carbon fiber grill surround, but it is much more money than I would like to spend and I don’t plan on putting carbon fiber anywhere else on the car.
    Thank you for your help.
  2. Tideland Prius
    16,658
    If I’m not mistaken, the base LE model has a black plastic surround so you could use that.
    Gorgonzola and ORWolf like this.
  3. Mendel Leisk
    42,173
    Or mat-black plasti-dip? If you change your mind you can peel it off. If you don't change your mind but it's starting to wear, peel it off and spray paint it.
    ORWolf likes this.
  4. mva
    mva Active Member
    171
    100
    B.C. Canada
    2024 Prius Prime
    SE
    Following this thread.
    I’m wondering if anyone in Canada is interested in trading black grill for silver? Maybe someone with a silver Prius?
  5. ORWolf
    ORWolf New Member
    Oregon
    2024 Prius
    Limited AWD-e
    Thank you for your replies. Can anyone confirm that the LE model has the black plastic grill surround? I’ve been looking at photos on the internet and they are not detailed enough to determine if the LE grill surround is black or grey (and shadowed in the photo).
    If the LE version is black, do you have a recommended place to purchase this piece? (Other than the parts department at my dealership.)
  6. CooCooCaChoo
    CooCooCaChoo Senior Member
    962
    544
    Cow-lee-fornia
    2023 Prius
  7. Winston Smith
    Winston Smith Active Member
    452
    315
    OH
    2024 Prius
    LE AWD-e
    Now I'm curious about whether the plastic piece from a dealership is available at all, and if it is any cheaper than the CF aftermarket piece.
    Your fuelly record is nuts.
  8. Hammersmith
    Hammersmith Senior Member
    2,428
    2,483
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I don't think it's fully black, but a dark dark gray. About the same color as the LE/SE wheel covers. But take that with a grain of salt since I never paid that close attention to the one I saw in person.
    I believe the part you are looking for is: 53112-47370 Grille, Radiator, Lower (big warning at the bottom)
    MSRP of $118.29, can usually be found for $81.79, currently $65.43 and free shipping if you order in the next 12 hours from Lewis Toyota
    (Lewis does 31% off standard, there's free shipping on any order over $75, and there's an additional 20% off sale running through midnight PST Oct 31 - the free shipping is calculated after the 31% but before the 20%)
    Warning: I was trying to figure out why the LE lower grille was so much cheaper than all the rest(others = $275-$300 MSRP) when I finally realized the LE is the only one without the lower "fog" lights. The lights are built into the lower grille, so I don't know if there's any way to get an LE grille to work on a LTD. Maybe there is, but it's totally at your own risk. At $65, it might be worth ordering just to give it a try, but it's up to you.
    Here are the part numbers for the four versions of the lower grille:
    53112-47370 - LE - dark gray inner section, no fog lights
    53102-47220 - XLE/LTD - silver inner section, fog lights
    53102-47230 - SE - silver inner section, no fog lights - need to also buy fog light covers
    53102-47240 - XSE/XSE+ - silver inner section, fog lights
    The PHEV versions seem to be slightly different, and I don't know if they're compatible with the HEV versions. The differences might only be cosmetic(slightly different shade of silver) or there may be mounting differences if the PHEV has a different cooling setup that the grille has to account for.
    ORWolf likes this.
  9. KMO
    KMO Senior Member
    2,022
    744
    Finland
    2023 Prius Prime
    That would make sense - the PHEV does have one big variable speed fan, while the HEV retains the two-fan setup used in previous Priuses (which runs two in series for slow, or two in parallel for fast - can't remember if it can run only one).
  10. ORWolf
    ORWolf New Member
    Oregon
    2024 Prius
    Limited AWD-e
    Thank you so much for all of this information.
  11. ORWolf
    ORWolf New Member
    Oregon
    2024 Prius
    Limited AWD-e
    Thank you everyone! I definitely don’t want to lose the function of the fog/accent lights. From what Hammersmith found, it looks like in order to have the oem black lower grille, I have to give up the lights. I guess the best option now is to paint over the silver. I’m going to discuss the possibility of this with a local body shop. Thank you again to everyone for their input.
  12. RobotBastard
    RobotBastard Junior Member
    Connecticut
    2024 Prius
    Thank you all for looking into this, because it's something I want to do as well (that's basically the only silvery-trim piece on the car, so it stands out, and being silver plastic it looks hella cheap). I did figure that the best plan was to just spraypaint it, but it's good to see confirmation.
  13. JohnnyPR
    JohnnyPR Member
    96
    25
    Hinesville, GA
    Looking forward to the photos.
  14. priusdriver223
    84
    32
    Lala Land
    2023 Prius
    XLE AWD-e
    Hey there, you can definitely keep your foglights even if you switch to the black one. You can remove the black part of the grill from the rest of grill unit and just retrofit it onto your current bumper, it does require you to take off your front bumper, it might take time but this definitely will work if you want to retain your fog/accent lights. Cheers!
  15. Hammersmith
    2,428
    2,483
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    You now have another option. The new Nightshade edition for 2025 is basically an XLE but also has a completely black grille. I don't know what the part number for the new grille is yet, but it should be exactly what you were looking for.
    PhoS likes this.
  16. PriusAWD
    PriusAWD New Member
    CA
    2024 Prius
    LE AWD-e
    I would have traded you but yes you need to keep your foglights.
  17. ORWolf
    ORWolf New Member
    Oregon
    2024 Prius
    Limited AWD-e
    Hi Everyone. Just an update. I had my front grille wrapped in black and I installed the Etsy shiny black front emblem. I really like the look without the silver grille. I also tinted the sides and back at 35% and the front windshield at 50%. I also had black wheels installed. So…. The car is completely black and red now. Thank you to everyone who responded to my original post!
    mva and xliderider like this.
  18. ORWolf
    ORWolf New Member
    Oregon
    2024 Prius
    Limited AWD-e
  19. mva
    mva Active Member
    171
    100
    B.C. Canada
    2024 Prius Prime
    SE
    Love it! I’m going to do something similar with my red SE prime. Looks much better in my opinion.
  20. Teez
    Teez Junior Member
    37
    Toronto
    2025 Prius Plug-in
    SE
    This looks amazing and is exactly what I want to do to my 2025 Black SE once i get it late March . Not sure why Toyota made that one front piece silver and the front badge chrome, really bad idea imo. Can you share more info on where you got the black front badge and how you went about changing it from the stock one? This is the first thing I want to do once I get mine but don't want to wreck my brand new car or my wife will be livid.
