Black Glass chipping away
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by tedblais, Mar 19, 2024.
  1. tedblais
    tedblais Junior Member
    I have this problem (see photo) and it appears to be getting worse. Any ideas on how to fix or stop it?
    Thanks!
  2. Myric227
    Myric227 New Member
    Three Touring
    I just replaced mine recently. I was going to use some plastidip, but then I found them cheapish at Amazon. Just search ZONFANT 2 Pcs Left and Right Rear Quarter Molding Cover Compatible with 2016-2021 Toyota Prius, Replace#62505-47012 62506-47012. Common issue and no way to really stop it from happening from what I've found.
  3. Mendel Leisk
    38,644
    Take a picture backed out a little further, for help with location/orientation?
    There is a triangular piece just behind rear door window glass, that's prone to peal. It's just painted plastic though IIRC.
    Doug McC likes this.
  4. Doug McC
    Doug McC Active Member
    997
    374
    Midwest
    2022 Prius
    No offense Ted, but what are we looking at? Maybe a fence?
  5. dbstoo
    dbstoo Senior Member
    1,321
    700
    Near Silicon Valley
    2024 Prius Prime
    XSE Premium
    The 2016 -> 2022 have these nice little fashion inserts between the rear passenger doors and the lift gate. The triangular insert is made of carbon fiber that was sanded super smooth and then painted with clearcoat (acrylic spray paint). The word is that the clear coat overheats in the sun, causing it to expand and shatter.
    I found that the clear coat was removable with pure acetone. After careful cleaning you can repaint the surface with krylon clear enamel spray paint.
  6. Mendel Leisk
    38,644
    Visual aid, maybe this:
  7. tedblais
    Sorry! Yes its the is a triangular piece just behind rear door window glass.
    How do you remove it?
    Thanks
    #7 tedblais, Mar 20, 2024
  8. dbstoo
    1,321
    700
    Near Silicon Valley
    2024 Prius Prime
    XSE Premium
    Removing it is similar in concept to removing the door's inside panel. It has several plastic clips that can be popped out of the car body, but then it has a gummy adhesive that has to be carefully removed with a thin plastic knife. There's a thread on that online, though I don't recall where. :)
  9. tedblais
    Found it. It seems pretty easy. Thanks everyone.
  10. Mendel Leisk
    38,644
    See this comment on the video, hopefully correct:
    2017 Prius. Replaced with Part numbers 62505-47012 Right side 62506-47012 Left side. There has been several iterations (-10, -11, -12) since original.
