Black Plastic and Wax
Discussion in 'Gen 2 Prius Main Forum' started by snowdog650, Mar 28, 2007.
  1. snowdog650
    snowdog650 Member
    171
    27
    Sacramento, CA
    Just waxed the new whip yesterday, and made new -- pleasant -- discovery of the Prius:
    The black plastic trim pieces on the exterior of the car are SMOOTH, and do not have ANY texture to them.
    What does this mean?
    NO car wax residue is left behind, causing unsightly white spots on the black. Wax simply wipes right off.
    Not a major thing, I know ... but just goes to show the amount of detail that 'Yota put into their design. My wife could not understand my small moment of joy,, however, and she proceeded to shake her head slowly and walk away.
    <_<
  2. Bill Merchant
    Bill Merchant absit invidia
    4,096
    81
    I understand.
  3. Tom6850
    Tom6850 Retired
    895
    Macungie, Pa
    Haven't waxed mine yet, but that is terrific news.
  4. Syclone
    Syclone Member
    540
    <div class='quotetop'>QUOTE(snowdog650 @ Mar 28 2007, 09:48 PM) [snapback]413898[/snapback]</div>
    <div align="center">Please! Before it's too late</div>
    <div align="center">GET A LIFE!</div>
  5. filiberti
    filiberti Junior Member
    58
    Georgia
    Not so sure about that . On my 2004 Prius I made mistake of waxing the black trim around side windows
    and IT STAINED . I was using Meguiar's Wax if that made a difference . Now on my 2007 I am making sure NOT to get wax on the BLACK TRIM including the rubber trim around bottom of bumpers . I like Meguiar's cause I found that wax easiest to remove , reg Meguiar's in red bottle.
    I'm not crazy about the newer NXT Tech wax they got I find that harder to remove . But it was the original brand that had stained my black metal pieces, I never was able to remove it . just a heads up
  6. snowdog650
    snowdog650 Member
    171
    27
    Sacramento, CA
    <div class='quotetop'>QUOTE(syclone @ Mar 29 2007, 05:41 AM) [snapback]414084[/snapback]</div>
    [/b][/quote]
    You are what we refer to in law enforcement as an "Adam Henry."
  7. onerpm
    onerpm New Member
    477
    MN
    <div class='quotetop'>QUOTE(snowdog650 @ Mar 28 2007, 08:48 PM) [snapback]413898[/snapback]</div>
    I wouldn't jump to that conclusion. Probably a $ thing.
  8. NoSpam
    NoSpam Junior Member
    46
    Arizona
    <div class='quotetop'>QUOTE(snowdog650 @ Mar 29 2007, 08:17 AM) [snapback]414152[/snapback]</div>
    Also known as "Richard Cranium". :D
    Best regards,
    NoSpam
  9. qbee42
    qbee42 My other car is a boat
    18,058
    3,073
    Northern Michigan
    Wax on, wax off...
    Tom
  10. zqfmbg
    zqfmbg New Member
    134
    [/b][/quote]
    Off-topic, but I really really wish the expression "get a life" would just go away and die already. It's always been pathetically meaningless, but a decade (plus?) of people abusing it have eroded away the very little bit it could have stood for. You may as well yell "YOUR MOM". :blink:
  11. subarutoo
    subarutoo New Member
    1,213
    23
    Chatsworth, CA
    I had some bodywork done, and the shop left white overspray on the black trim around the passenger door. I used Megiuar's cleaner wax, and the overspray came off very nicely. No residue, etc. It probably wouldn't be so good on the plastic around the windshield wipers, but door and window frames..yes.
  12. Tideland Prius
    16,017
    It won't go away if you accidently wipe wax on the black plastic below the wipers. You'll need to use peanut butter to remove that.
  13. Spoid
    Spoid New Member
    286
    <div class='quotetop'>QUOTE(qbee42 @ Mar 29 2007, 12:06 PM) [snapback]414359[/snapback]</div>
    but which hand is which?
