Black Plastic Undercarriage Falling Off
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Metrolens, Mar 9, 2018.
  1. Metrolens
    Metrolens Member
    190
    35
    The black plastic undercarriage strip of my 2005 Gen2, which attaches to my front bumper, is falling off. It normally attaches by three screws, but as you can see, the attach points are all broken through, so it may be difficult to reattach the screws. This should be a pretty easy repair, but I thought I'd post first here for advice before proceeding.
  2. M in KC
    M in KC Active Member
    358
    106
    KC, MO
    Zip Ties.
    Metrolens and SFO like this.
  3. Metrolens
    Metrolens Member
    190
    35
    Yeah, zip ties. I imagine I have to drill new holes somewhere in the silver plastic, to thread the zip ties through and cinch the black plastic tight. But that seems a very workable solution.
  4. dolj
    dolj Senior Member
    7,652
    3,865
    Wellington, New Zealand
    I use an ice cream container lid and some plastic weld type glue to make reinforcing pieces on the back of the bumper plastic. Then used the normal fixing clips and bolts to put it all back together. A bit more work, but a nicer finish, if you can be bothered. Same technique also works on the black skirt plastic, if those fixing holes get torn out.
  5. Mendel Leisk
    38,720
    I think you can use a soldering iron to actually weld rips. Never done it though. You would want to practice, maybe pre-warm with a heat gun too.
    I have used 2-part epoxy and fiberglass mesh reinforcement, worked pretty good.
  6. valde3
    valde3 Senior Member
    2,002
    745
    Finland
    Repairs using soldering iron or plastic welder are pretty easy. Once you get used to that you won’t go back to using glue or fiberglass resin (especially if you ever try to plastic weld a part that has previously been repaired with glue/resin).
