Black Printed Wheel
Discussion in 'Gen 3 Prius Accessories and Modifications' started by tzh, Jun 20, 2010.
  1. tzh
    tzh Member
    105
    Maryland
    Black Painted Wheel
    Painted my A3 wheels over the weekend. The color I used is black night metallic. Also installed HID kit.
    I am thinking to paint the Prius wheels white but not sure how it will turn out. Any thoughts?
  2. Nuckz23
    Nuckz23 Member
    127
    Santa Clara, California
    Looks good. What type of paint did you use?
  3. HI MPG
    HI MPG Active Member
    789
    133
    93
    Orange County, CA
    Not sure how white wheels will look on a blue car... I think if you go white, you should paint them a matte white. Or go gold, maybe bronze. I think those two colors will match the blue.
  4. tzh
    tzh Member
    105
    Maryland
    Here is the spray paint I used.
    2 coats of primer and 3 coats of paint :)
      File size:
      100 KB
      681
      File size:
      80.9 KB
      613
  5. tzh
    tzh Member
    105
    Maryland
    Thanks, more like this
  6. HI MPG
    789
    133
    93
    Orange County, CA
    Exactly! :)
  7. PriusV
    PriusV Junior Member
    CA
    I should have read this post before commenting on another. I asked if it's possible to get the rims powder coated (black.gun metal)instead? Is it even possible and how much would something like that cost?
    not sure about white either.
  8. HI MPG
    789
    133
    93
    Orange County, CA
    I had my stock 15s powder coated a matte bronze. The total cost was approximately $290.
  9. tzh
    tzh Member
    105
    Maryland
    Do you have pictures of it?
    Thanks
  10. HI MPG
    789
    133
    93
    Orange County, CA
    I'll try to get a picture later on tonight. I was a bit disappointed with the color... didn't quite come across as metallic as I wanted, so... well, I'll let you be the judge of it when I upload the pict.
  11. HI MPG
    789
    133
    93
    Orange County, CA
    So here are the pictures...
  12. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    That's a tough paint. I used that silver metallic (basically clear with silver flecks in it), over a silver base for door hardware in my old house, and it took a beating and help up well.
  13. tzh
    tzh Member
    105
    Maryland
    Well, painting was not an issue. Sanding took most of the time.
  14. tzh
    tzh Member
    105
    Maryland
    Thanks for the pictures.
    I wasn't sure about dark rims on a dark car. But yours are NICE :rockon:
  15. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    FWIW, I powder coated my Gen II Touring wheels.
    They aren't black... but then neither is Amapola. ;)
    A three-coat treatment; base, metalflake, and clear topcoat. IIRC ~$600
    including stripping OEM finish to bare metal, Scotchbright finish at rim's
    edge, and masking rim for base and metalflake coats, removed for top
    coat.
  16. tzh
    tzh Member
    105
    Maryland
    Man :eek:
    IMO, that is a bit extreme but look pretty nice. How about paint the brake to red? :D
  17. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    "Extreme?" I'd say only to the extent that the treatment is different
    from the current industry wheel treatment default; clear coated alloy
    or silver. I see black cars with black rims quite often and white cars
    with white rims on occasion. So, color matching isn't too far out there.
    More on my reasoning here.
    As to the brakes. The drums on the rear are OEM black. If I were to do
    anything else, I'd paint the front brake calipers black to de-emphasize
    them. To do it right, they'd have to come off and that might mean
    bleeding the brake lines which I've read can be difficult for a non-
    mechanical type like me.
    Since I had my wheels done a little over a year ago, I've seen four
    other cars with red painted wheels, two of the cars were silver, one
    black, and one white.
    And just the other day I saw a blue Ford Focus with white wheels.
    Now that is bordering on the "extreme." :p
    There's no accounting for someone's taste or sense of style is there? :cool:
