Black rubber liners
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Codemonkey812, Oct 26, 2016.
  1. Codemonkey812
    Codemonkey812 Junior Member
    22
    Kent, Ohio
    I just purchased a used 2013 Prius Persona. It is missing some of the black rubber liners that go in the interior door handles (covers on the screw in the recess you use to pull the door close), and the bottom of the center console (between the two front seats). Does anyone know where I can order some, and if they have a proper name?
  2. Wolfman33
    Wolfman33 Member
    43
    26
    Virginia Beach, VA
    2022 Prius Prime
  3. Codemonkey812
    22
    Kent, Ohio
  4. Mendel Leisk
    38,653
    Those are SO easy to suck up with a vacuum cleaner. :mad:
    If you have any not missing, you can cobble replacement by getting some rubber matting from a hardware store, or heavy felt, what have you, and trace the pattern of the one you have onto the material, cut it out. If they're all missing still doable, with a little trial-and-error.
