Black shift knob?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by petteri, Dec 24, 2003.
  1. petteri
    petteri New Member
    203
    Plantation, FL USA
    Does anyone out there have a black shift knob as seen on some of the prius photos from Toyota? I have the ivory interior and the end of the knob is silver in color. Its a small detail but I really liked the look of the black knob. Thanks! If this is an option somewhere (ie Europe, Japan) perhaps a part number can be dug up?
    Petteri
    Miami, FL
  2. talonts
    talonts VFAQman
    448
    69
    Unless you've seen it on a regular street Prius, rather than on Toyota's site, don't assume it is an option. It might have been pre-production.
    The NCF shows how the light-pipe is built into the knob, so if you use an aftermarket knob, you'll lose the lit pattern, unless someone creates one with the light-pipe shift pattern in it (HIGHLY unlikely in a low volume car).
    Bottom line, unless someone in Japan replies with a part #, you'll probably be out of luck.
    There's always paint ;-)
  3. petteri
    petteri New Member
    203
    Plantation, FL USA
    That's what I've concluded. Oh, well. I've gotten used to the gray knob now anyway. Thanks!
