Black Silicon: Will the new Prius be covered in this stuff?
Discussion in 'Gen 2 Prius Main Forum' started by Sufferin' Prius Envy, Oct 12, 2008.
  1. Sufferin' Prius Envy
    Sufferin' Prius Envy Platinum Member
    3,998
    "Forcing sulfur atoms into silicon using femtosecond laser pulses creates a material called 'black silicon' that is 100 to 500 times more sensitive to light than conventional silicon, in both the visible and infrared spectrums, according to SiOnyx, a venture-funded Massachusetts start-up that just emerged from stealth mode."
    SiOnyx Brings “Black Silicon” into the Light; Material Could Upend Solar, Imaging Industries | Xconomy
    Slashdot | "Black Silicon" Advances Imaging, Solar Energy
    One hundred to five hundred . . . that's a lot of "times." :eek:
    They aren't just talking double or five times.
    With that kind of solar power potential, how much further will a plug-in Prius be able to go without the need for the ICE to start? . . . or will a black silicon car be able to relegate an ICE to just a small emergency generator?
    This could get very interesting. :)
  2. fish_antlers
    fish_antlers New Member
    200
    Ca
    no... the prius is a dispose-a-car ... hate to burst your bubble ... prius is an econo-box budget vehicle made poorly or mostly low grade components and meant to be used up and thrown away.
    sad but true.
  3. richard schumacher
    7,664
    1,043
    United States
    In very round numbers it takes about 50 HP or 35 kW to run a car. Sunlight provides a bit less than 1.5 kW per square meter. Ideal photovoltaic cells (which do not now exist) would capture about 1 kW per square meter; existing PV cells can capture about 0.2 kW per m^2. If you covered a Prius with ideal PV cells you could possibly run the car for 1/2 hour after leaving it in the Sun all day in Phoenix in June. With real PV cells in real time you might be able to capture enough Sunlight to run the air conditioner.
  4. hill
    8,641
    Right! (speeking of bursting bubbles :p) That's why:
    1) Consumer Reports gives the Prius (year after year) its highest quality mark.
    2) Taxi companies are logging 300,000 miles and beyond with their Prius fleets
    3) (relating to thrown away) Toyota has procedures in place to recycle any/all elements of the Prius if / when it ever does finally wear out
    4) (relating to econo box) Prius' cost is higher than equally equipped mid sized cars so no telling where the 'econ' phrase came from.
    Me thinks the baby has smoked one smoke too many, what with each & every fact being so thoroughly messed up :D
    Now, with that sillyness out of the way, and segway'ing back to the topic, the solar panel manufacturing process has many new technologies on the drawing board. Ultimately, their cost and efficiency must be weighed together. Like hydrogen ... if you end up spending more the 4x the amount of energy, just to get the energy, it won't come to pass. I for one hope this or some other solar technology makes our existing solar panel's efficiency out dated.
  5. SW03ES
    SW03ES Senior Member
    2,480
    176
    Gaithersburg, MD
    If you think the Prius is an "econobox throw away car" you should sit in a Chevy Aveo or a Yaris or something like that. The Prius is much nicer and if anything has excellent quality materials for its price point.
  6. ElectricBlue1
    ElectricBlue1 Junior Member
    Michigan
    Ok...I traded my Escalade for the Prius. Cadillac makes (or used to make) a real quality product. But i have to tell you, for less than half the cost, more than 4 times the gas mileage, the Prius is every bit as comfortable, quiet, and has more rear leg room than the Caddy. Just my two cents, but I don't miss the Caddy at all!
  7. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    I thought he was joking about a diposable econobox...maybe not.
  8. kenmce
    kenmce High Voltage Member
    1,544
    515
    NY
    Easy there buddy. Right now it's just a lab observation.
  9. auricchio
    auricchio Member
    921
    Cambria, CA, USA
    Never mind the extra equipment and weight required to build real-world solar panels and the electronics they require.
    A report of one lab breakthrough---assuming it's been peer-reviewed and duplicated---is no guarantee that we'll ever see real product.
  10. kevinwhite
    kevinwhite Active Member
    333
    200
    Los Gatos Ca
    The average consumption at 60mph is more like 15HP.
    10-15% is a more typical efficiency photovoltaic efficiency (because of the bandgap, ideal silicon photovoltaics can only convert about 22% of sunlight to electricity). Multilayer cells using exotic materials can get up to about 37% efficiency.
    kevin
