Blade refill part number for 2018 C
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by John in Vermont, Aug 30, 2018.
  1. John in Vermont
    John in Vermont Junior Member
    32
    Rochester, Vermont
    2018 Prius c
    Can somebody post the Toyota part numbers for the left and right wiper blade refills on a 2018 Prius C?
  2. dubit
    dubit Senior Member
    850
    538
    23
    Indiana
    2016 Prius c
  3. John in Vermont
    32
    Rochester, Vermont
    2018 Prius c
  4. cutter44
    cutter44 Member
    213
    MA
    The driver's side blade on my 2012 is 28". Passenger side is 14". I've bought OEMs from Beach Toyotas via eBay in the past. But last time I bought AEROs from Amazon and they've been fine. I'll probably go with them again next time I need blades rather than futzing around with inserts.
    - apparently I can't post as link to the Amazon blades. Either I'm doing something wrong with the link or the forum doesn't allow it.
  5. John in Vermont
    32
    Rochester, Vermont
    2018 Prius c
    Thanks for your reply. An extensive online search turns up only 26 inch blades as the proper size for earlier Prius C's, that's why I'm asking for the Toyota part number. I'm going to measure the blades on older C's that I see parked to see which size is typical.
