Blade voltage reduced to 2.93v from 3.66v
Discussion in 'Prius v Technical Discussion' started by Ohid, Feb 24, 2022.
  1. Ohid
    Ohid Member
    157
    Dhaka, Bangladesh
    2015 Prius Alpha
    Why blade voltage reduced when all other values (Pack voltage, IR, Block voltage) remain same. Same car after 7 months.
    Blade voltage shows now under 3.0v whereas 7 months ago it was 3.65v . But Pack voltage and IR remain same as before. As well as minimum block voltage is more than its nominal voltage 25.2v.
    Any explanation?
