Bleeding brakes from 2012 Prius with pneumatic bleeder
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Ryan Gallo, Sep 3, 2024 at 8:19 PM.
  1. Ryan Gallo
    Ryan Gallo Junior Member
    Seattle
    I’m replacing the brake pads and rotors on my 2012 Prius and am going to bleed the brake fluid as well. I purchased a pneumatic brake bleeder from Amazon, linked below, and was wondering if this can be safely used on both the front and back brakes as long as I first put the Prius into INVALID mode?
    I’m mostly worried about the back brakes as I know they have the electronic pump system.
    And I won’t need a friend, right?
    Bleeder:
    EWK 23 Pcs 2L Pneumatic Vacuum Brake Fluid Bleeder Extractor Pump Kit + 1L Refilling Bottle
  2. MAX2
    MAX2 Member
    221
    48
    Third Rock from the Sun
    You don't need this.
    Brake bleeding is done by the Prius itself. It re-pressurizes the system with a slight pressure leak.
