Blind spot/post question
Discussion in 'Gen 3 Prius Main Forum' started by pyccku, Aug 21, 2009.
  1. pyccku
    pyccku Happy Prius Driver
    235
    Surprise, AZ
    I have a genII and the one problem I have with the car - the ONLY problem I have with it - is the blind spot caused by the post between the front and rear doors on other side. I have a hard time with lane changes due to it, I always check several times b/c I know it's so easy to miss something due to that post.
    Does the gen3 seem to have a similar issue? I'm thinking of taking a test drive just to try it out, but I'd like to get some input here first.
  2. fgp
    fgp Active Member
    503
    169
    daytona
    2023 Prius
    i think most cars have some sort of blind spot . my solution is the inch and a half round dollar ninety nine convex mirror. i put this on every vehicle ive had for the last ten years. :)
  3. 32kcolors
    32kcolors Senior Member
    5,683
    953
    124
    Redondo Beach, CA
    Instead of some el cheapo convex mirror which uglify the car, adjust your side mirrors outward until you can no longer see the side of the car and this should eliminate 75% of the exisiting blind spot. You don't need to see your face or the car's body in the side view mirrors.
  4. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    I have a small "el-cheapo" rectangular mirror. I've got/had them on all my cars, except the Triumph, for years and years. Better safe than stylish, I guess.
