Blinking temperature #
Discussion in 'Prime Main Forum (2017-2022)' started by bill188, Feb 10, 2018.
  1. bill188
    bill188 Junior Member
    Aurora, Colorado. USA
    Its 19° in Denver, CO right now, at least that's what my Prius Prime says. My car had been sitting outside for a couple of hours and when I got into the Prime and pressed the start button, the Temperature number was blinking. It blinked about 5 time and then didn't blink any more. I wasn't sure what that mean but I took my car out of The default EV move and switched it to HV mode and the engine came on. Any thoughts out there in Primeland?
  2. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    It blinks when it's below 32 F
  3. Diemaster
    Diemaster Active Member
    290
    260
    so. cal
    1. it might be a frost or freezing warning.
    2. might be a fault with the sensor and or wiring.
    thats all i can think of right now.
  4. bill188
    I've never noticed that before. What does it supposed to mean , other than it's cold out?
  5. DavidA
    2,328
    1,812
    Chicago western burbs
    It blinks when the outside temperature is below 32 degrees F. That's just what it does. There is no fault in any wiring.
  6. Elektroingenieur
    2,515
    3,259
    Three Touring
    Owner’s Manual (PDF), page 197: “The temperature display flashes for approximately 10 seconds when the outside temperature drops to approximately 37°F (3°C) or less, and then stops flashing.”
    Beware of ice on the road. It’s a standard safety feature; my German car, for example, had a snowflake that appeared when the outside temperature was below 41 °F.
    bill188 likes this.
  7. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,318
    Central Virginia
    On the Gen 4 it blinks at 37 F or less for 10 seconds, according to the manual.
    It is warning there could be ice on the roadways.
    bill188 likes this.
  8. huskers
    huskers Senior Member
    2,543
    2,486
    Nebraska
    It is telling you to be careful. Black ice can form when at the blinking temp or below.
    bill188 and Prodigyplace like this.
  9. Dm84
    Dm84 Member
    60
    38
    MA
    It's just a reminder that it's cold out. Don't sweat it.
    bill188, benagi and Prodigyplace like this.
