Blizzard and cold caused strange issue
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by KMAN4190, Feb 9, 2013.
  1. KMAN4190
    KMAN4190 Junior Member
    57
    Hello. We got clobbered with 30 inches last night. I dug out car this afternoon and I started it to move it in my driveway so I put it in drive and there was a flashing yellow triangle alert and dashboard said something about being in park but car was in drive. It was either transmission was frozen or too much weight still on roof. I shut it off waited a while and started it again. When gas engine kicked in and roof cleared it seemed ok. I can't test drive because you need landcruiser to get around now. Any comments on what that could have been? Thanks
  2. Mendel Leisk
    38,873
    Where are you?
  3. KMAN4190
    57
  4. john1701a
    john1701a Prius Guru
    12,760
    5,246
    57
    More likely, it was you taking extra safety into account. A very common thing to do when there's lots of snow is to pull away with the door open for increased visibility. Prius doesn't want that, sounding & displaying a warning to inform you to stop.
    Having driven Prius in Minnesota for well over a decade, I can tell you with great certainty that cold & snow aren't an issue. So, no need to worry. When you do finally see an end to that mess, you'll see that all is well.
    Good job with all the shoveling!
    Thanks for sharing the photos.
  5. KMAN4190
    57
    Sounds good to me! Thanks
  6. IMkenNY
    IMkenNY Im just being nosy
    477
    303
    Tropical Buffalo NY
    Four Touring
    seat belt not on.....door not completely latched?
  7. KMAN4190
    57
    No seat belt. Door maybe open/not closed all he way.
  8. Mendel Leisk
    38,873
    Yeah thanks for the pics. My better half's in NYC right now ;)
  9. KMAN4190
    57
    Roads are terrible. Cars littering main roads so plows can't get by. It came fast and furious. Hope she is well
  10. Rob.au
    Rob.au Active Member
    960
    441
    Sydney, Australia
    i-Tech
    Just on the seatbelt warning... sheesh. I just washed my car in the development's one wash bay which is - no joke - about a 400 metre drive from my spot. Drove it back without the belt on partly because I was a bit wet and boy was the car unhappy about it. First is was just the flashing red seatbelt indicator. Then it started beeping incessantly. After a bit of that it turned up the volume of the beeping to an ear piercing level that continued not just until I stopped, but right until I actually shifted into reverse.
    This car is such a carry on when it's not happy about something.
  11. rjdriver
    rjdriver Active Member
    407
    168
    Rhode Island
    I can't decide if that snow you left on the roof gives the car a mohawk cut, or looks like an extra large shark fin:)
  12. iClaudius
    iClaudius Active Member
    435
    135
    Kansas
    Those have specific lighted warning signs on the dash. Neither causes a flashing triangle as described. I often have things on the front seat and the seatbelt light will flash and run an audilble alarm. Door open, same thing.
    Weight on the roof would't create the alarm as it is much less than four people in the car.
    Don't think it was the cold as my Prius hatchback endures 10 degrees in the snow with no complaint.
  13. KMAN4190
    57
    It was definitely a triangle shaped yellow warning light.
  14. sph101
    sph101 Prius 4
    156
    92
    32
    Brevard, NC
    2018 Prius
    one of the reasons that the triangle Indicates that the driver’s door was opened with the shift position in N, D or B A buzzer also sounds. (all of the indications from this triangle can be found on pg 431 of the owners manual)
  15. dick_larimore
    dick_larimore Member
    162
    70
    Central Indiana
    You can push the ON button (with the brake pedal depressed) and shift into drive faster than the car can respond. You end up in reverse or drive with the warning triangle flashing. I then must shift back into park and hit the ON button again. I have done this numerous times and a second restart always solves the problem.
    Rob.au likes this.
  16. KMAN4190
    57
    Sounds like that might be it. Thanks
  17. Rob.au
    960
    441
    Sydney, Australia
    i-Tech
    Has happened a few times to me also. The display screen will have a message telling you to shift back to P and press Start (or the non-SKS equivalent).
