blizzard white w/ 15" wheels and drop
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Joshua, Sep 6, 2012.
  1. Joshua
    Joshua Junior Member
    56
    Atlanta, GA
    Ive looked through the photo section and found tons of blizzard white prii with all different sizes of wheels but I couldnt find specifically any with 15" wheels and say the toyota prius plus springs.
    I dont like the look of the stock 15s that much maybe they would look better with the covers removed but most pictures of them removed is hard to see where the tire stops and wheel begins.
    I want to stay with 15s to keep my mod budget down and be able to re-use my stock tires, and not add the extra weight of the bigger tire/wheel combos.
    and i would also like to find out what the ground clearance on the front and rear after the prius plus springs would be on stock sized tires.
    I have to make sure it'll clear my driveway as well.
    thank you
    Joshua
  2. mrstop
    mrstop PWR Mode
    742
    329
    109
    Cincinnati, OH
    I took some measurements the other day. I used the Tien H-Tech for a drop comparison.
    Stock" Drop" New Height"
    Front spoiler 7.25 1.40 5.85
    Front center jack point 7.00 1.40 5.60
    Front jack points 7.25 1.40 5.85
    Mid low point Center Brace 6.25 1.45 4.80
    Rear jack points 8.00 1.50 6.50
    Front wheel gap 2.50 1.40 1.10
    Rear wheel gap 3.00 1.50 1.50
