Block heater has died
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Dark_matter_doesn't, Oct 20, 2014.
  1. Dark_matter_doesn't
    Dark_matter_doesn't Prius Tinkerer
    691
    151
    Seattle, WA
    Infinite resistance, doesn't draw current. It's been installed for a few years. It was a Toyota of Canada part.
    Anyone else have theirs die? Is this to be expected?
  2. Mendel Leisk
    40,574
    We've used ours a lot, virtually every first start of the day. Not driving the car every day, maybe every other day now.
    Block heater still fine, though I did drag the plug down the road one time, ground it half off. Spliced in a replacement, no further problems. Could it be a problem with the plug, or the last few feet of the cord?
    Not sure how you test this without cutting a foot or two off. Maybe with a pin probe through the insulation? Resistance should be in range of 30~40 ohm I think, when it's good.
    Dark_matter_doesn't likes this.
  3. PriusGuy32
    1,417
    513
    Harrison Township, Michigan
    The cord went bad on my Gen2's EBH after just 1.5 winters, had an open. Worth a shot to rule out, if you were measuring at the cord vs. at the block heater prongs itself.
  4. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    So yall do have Plug-ins.
  5. Dark_matter_doesn't
    691
    151
    Seattle, WA
    Thanks for the cord check ideas. I don't recall seeing any reports here of block heater failures.
    PriusGuy32 likes this.
  6. Mendel Leisk
    40,574
    I recall someone visiting Alberta from southern US, and the locals had him half-convinced that plugins were big there: pretty much every driveway sported a vehicle with an extension cord running out to it. ;)
    I'm in lower mainland BC..., we saw someone SWIMMING at kits beach day before yesterday. I get some puzzled looks over block heater use year 'round.
  7. Dark_matter_doesn't
    691
    151
    Seattle, WA
    It was the plug. I used sharp probes to poke thru the cable insulation to determine this, plus that the heater is still 35 ohms resistance. I put a new plug on the cable, then discovered that my 110 VAC timer has a ridge that blocks the larger body of the new plug. Damn. Now I have a short extension cord connecting the heater to the timer.
    I do have a "plug-in" Prius, but the energy charge is in the form of heat, not electricity.
