Block heater plus car charger on same circuit?
Discussion in 'Prime Main Forum (2017-2022)' started by Spidey71, Aug 19, 2018.
  1. Spidey71
    Spidey71 Member
    60
    49
    Alberta, Canada
    2018 Prius Prime
    Just getting ready to prep the new Prime for its first Canadian winter. We have a heated garage, so no issues charging at home. However, my wife will be primarily using the car to commute to work (20 km one way) where she has a dedicated outside parking stall with an outlet (2 receptacles) on a post. These are intended for "block heater" use but I'm not sure if these are the type of circuits that cycle on and off every hour or if they supply constant power. I'll need to look into this as well as whether they are on a 15 or 20A circuit.
    In the meantime, I'm trying to think of a way for her to plug both the car charger and block heater in at the same time (assuming constant power). A couple consideration I have:
    1. One the first receptacle - install a block heater plug-in timer to come on the last 2 or 3 hours of the day, and on the 2nd receptacle, plug the car charger in and start "charge now" as soon as she gets to work which would then complete the charging before the block heater kicks in.
    2. If it's a 20A circuit would that be able to charge both a block heater and car charger at the same time?(apologies for my lack of electricity knowledge!) Toyota installed the block heater and I need to find out how many watts it is, but I'm assuming it will be relatively low (eg. 200-400W).
    Any other ideas or considerations?
  2. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    The block heater we had was about 400W. The L1 charger will draw about 12A including the efficiency loss, etc so that's 1440W. If both drawing power at the same time you're looking at 1840W draw which is 15.3A @ 120v. The rule is that for "continuous draw", something that will be on a long time versus something like a toaster that is on for 5-minutes a day, you don't want to load the circuit more than 80%. So you'd need a circuit just over 19A capable to safely provide that load assuming the breaker, wiring, and outlets are all properly connected.
    If you have a 20A outlet with nice wiring, then you're good to go. Just plug it in and don't worry about it. If you have a 15A circuit you'll be tripping the breaker when they're both on. If you have a 20A outlet with poor wiring to a 20A breaker you'll potentially have nuisance tripping and/or fire.
    If this outlet ONLY serves that outlet, meaning it isn't daisy chained to other outlets which would be unusual but awesome, then I would recommend swapping out the 5-15P/5-20P outlet to a 6-20P, and change the circuit over to 240vac. Tie the neutral wire to the second leg of the hot (and mark it with some black tape so that others that follow you know it is now a live hot wire) and now your outlet will have 240v across the 2 terminals and a ground. You can use a cheap EVSE to charge the car, and get a block heater compatible with 240v instead of 110v. Then the current draw in the wires will be halved for the same load.
  3. Spidey71
    Spidey71 Member
    60
    49
    Alberta, Canada
    2018 Prius Prime
    Thanks for the clarification and detailed explanation. She works at a relatively newly built school, so I'm assuming the wiring is solid and will check on whether it's dedicated or shared with other parking stalls and if it's 15 or 20A. If it's 15A, would setting the car charge rate at 8A instead of 12A work for both? I won't be permitted to change out any receptacles.
    That said, I'm leaning toward the block heater timer idea (heating for more than 3 hours is overkill and a waste of energy anyway...)
  4. bwilson4web
    15,513
    You might consider one of these:
    Titan Controls® Apollo® 9 - Two Outlet Digital Timer | Titan Controls
    You'd probably need a water proof housing and short extension cord rated at 20 A. The battery backup should work just fine. Conservative, I would stop the charger about 30 minuets before departure time and start the block heater. However, last winter's cold operation suggests a block heater might be of marginal utility. Better to have a block heater and not need it than the reverse.
    Good Prius friend @john1701a has more cold weather experience than me. You also have the option to use pre-conditioning to prepare the car including the cabin. This works best if you are still plugged in.
  5. Lucifer
    Lucifer Senior Member
    1,014
    485
    Nh
    If the garage is heated, why a block heater?
    Why not get an L2 circuit installed for charging?
    So, if the car is charging and you plug in the block heater and it blows the circuit, get an L2 charger, but why the block heater in a heated garage?
  6. bisco
    49,397
    or does he mean at work.
  7. john1701a
    john1701a Prius Guru
    12,754
    5,245
    57
    No one I know of, here in Minnesota, use block heaters anymore. That warmth to help with the startup simply isn't necessary for traditional vehicles nowadays. With a Prius, that's even more so of a non-issue... especially with a Prime. Think about how power that battery-pack can provide for turning over the engine. There's simply no real benefit, especially with regard to starting with a warm engine... since you won't with your drive starting from EV.
    The battery-pack in Prime has heating elements to keep it at a more efficient operating temperature. That's automatic. Nothing is needed. You can plug in to top off the EV capacity, but it isn't necessary.
    Pre-Conditioning the cabin prior to leaving work is meaningful, from a comfort perspective.
    KrPtNk and Trollbait like this.
  8. Spidey71
    Spidey71 Member
    60
    49
    Alberta, Canada
    2018 Prius Prime
    I mean when my wife charges at work and the car is outside during the day.
    Does anyone know if the pre-conditioning extends beyond the cab in into the engine bay? If so, I can't see how 15 minutes would help an engine/oil viscosity when it's -35.
  9. john1701a
    12,754
    5,245
    57
    Pre-Conditioning is only for the cabin using the electric heat-pump. At those extreme temperatures, just take advantage of the block-heater by starting the engine.
    This video is the cooldest I was able to capture last winter, which showed the warm-up process...
    This one wasn't as cold, but I started from being parked in the cold ramp all day rather than the garage at home...
    #9 john1701a, Aug 19, 2018
    Spidey71 likes this.
  10. PT Guy
    PT Guy Senior Member
    1,085
    710
    Washington, the state
    With a 20km (12 mile) drive each way, the total round trip might not deplete the battery even in the cold and snow. Your idea of reducing the draw to 8 amps is a good idea. Use that and the block heater.
    -35°F at the time school lets out? Even full synthetic 0W-20 oil in the engine will be like glue. Good to get it warmed before driving. The engine will run to provide heat--too cold for the heat pump to do its job. Will the traction battery be drawn down at all? Be ready to plug in both, but maybe only the engine heater will be what you need--she'll see the battery capacity remaining.
    Does anyone there use a battery heater (12 volt battery in the Prime, not the traction battery)? How about an oil pan heater under the transmission?
    Battery Heaters
    Silicone Pad Heater 25 Watt
    Watts = volts x amps. Or, amps = watts ÷ volts (neglecting power factor, line loss, etc.)
    Wattage is the measure of electrical power
    Voltage is the measure of electrical force
    Amperage is the measure of the rate of flow of electrons
  11. Spidey71
    Spidey71 Member
    60
    49
    Alberta, Canada
    2018 Prius Prime
    Yep, we'll get a handful of -35 days each year. At these temps, schools typically close and school buses don't run, but the odd time it might start out at -20 but get progressively colder throughout the day. Great idea on the battery warmer and oil pan heater. I installed an oil pan heater on my old F250 (gas engine) and connected it to the block heater plug with a two prong heavy duty extension cord. I have the extension cord (20ft) wrapped around my tow hooks off the front bumper and when I plug it in, both the oil pan heater and block heater kick in. Obviously I'd have to figure out something a bit more sophisticated for the Prime. I really like the notion of a block heater, battery heater and oil pan heater plugged in at once!
  12. Trollbait
    11,513
    Cutting charging to 8 amp is likely the way to go. You need to double check if that would allow cabin preconditioning. That is probably going to be more important than charging the battery with temps that low. The heat pump can only operate down to 14F(IIRC), so the the engine will be coming on anyway for heat, and if the defroster is turned on.
    Come to think about it, how does the car preheat the cabin if the temperature is too low for the heat pump? Does it simply not do it, or does the ICE come on like in most other cars?
    For the winter, you and your wife might have to accept that the Prime will be mostly running as a hybrid, at least for the return trip. The block heater will help with the start up penalty to efficiency. Yes, the engine warms up faster than in previous models, but these are extreme temps, and the commute borderline short trips. Good news is that you may not need the charge at work to drive home in EV during the summer, if they shut the heater block circuit off.
    Don't know if the oil pan heater is really needed. The oil will be hot after the drive in, the belly pan may supply some shelter to the oil pan from any wind, and the block heater will provide some heat to the oil. You might even be able to switch to 0w16 once it becomes available. That is what the new Camry calls for, I wouldn't surprised in older cars get recertified for it after some time, like Ford did with 0W20.
    I thought the battery heater was only powerful enough to keep the pack above freezing(0C), and not heat it enough for efficient charging?
    #12 Trollbait, Aug 21, 2018
  13. Salamander_King
    Salamander_King Senior Member
    10,970
    8,853
    New England
    Was this dealer installed block heater Toyota OEM or aftermarket? My Prime does not get as cold as your place, but being charged outside in subzero temp, I was considering installing one to mine.
  14. Spidey71
    Spidey71 Member
    60
    49
    Alberta, Canada
    2018 Prius Prime
    Good question on cabin conditioning using ICE in cold temps. With temps that low, I think ICE would be needed to warm the engine up anyway. If the conditioning function turns on ICE, then it's like having the benefit of a remote car starter in really cold temps. And yes, we're anticipating primary hybrid use for approx 4 months of the year given where we live. However, we are located a chinook belt so often have days or weeks well above freezing even in the dead of winter. Good point on the need for a oil pan heater - I forgot about the extra cladding/protection under the oil pan. I'll likely start with a battery heater which should be very easy/close to tie into the block heater with a small extension cord (vs. the cord fishing I had to do with the oil pan heater to get the cord to the front of my truck!)
    #14 Spidey71, Aug 21, 2018
  15. Spidey71
    Spidey71 Member
    60
    49
    Alberta, Canada
    2018 Prius Prime
    It was installed by the Toyota dealership after it arrived from Japan and was negotiated into the purchase price, so I'm assuming it's OEM. However, when we ordered the car in February the block heater was only available as an add-on option through the dealership, but by the time we took delivery in June, Toyota made them mandatory equipment for Canada. The block heater now shows up as an automatic pre-install on the Toyota Canada website.
    The quoted cost for the block heater and install was $400CDN
    #15 Spidey71, Aug 21, 2018
    Salamander_King likes this.
  16. Mendel Leisk
    38,653
    Those outlets very likely do cycle on and off. Just stick to charging the hybrid battery at home, simpler? She should be able to verify that on/off factor, checking with whomever manages the parking lot.
    I would plug in the block heater though. If it's per 3rd gen it's 400 watts.
  17. Salamander_King
    10,970
    8,853
    New England
    Wow, that's a bargain. If I can get OEM block heater on mine for that price ~$300USD, I would do it at once. Thanks for the info, I will look into the OEM parts and cost here in US.
    BTW, about charging your PRIME in cold, someone might have mentioned this already, but PRIME will starts ICE automatically when temp is below 14F (-10C). So, even if you have plenty of charge left in battery, when it gets extremely cold, your ICE is going to start. Depending on your travel, it may not be worth the trouble charging the battery full in -35C temp.
  18. Mendel Leisk
    38,653
    Log into Toyota Canada, "build" a new car purchase, add the block heater accessory, should show the current suggested retail cost. It used to be around $250 CDN, but I think of late it's jumped, low to mid $&300's.
    FWIW we were dinged $400 too, when we bought in 2010.
  19. Salamander_King
    10,970
    8,853
    New England
    Thanks. @www.toyota.ca it is listed at $347.50 installed for a new PRIME purchase. The price must be CAD. That's only $266USD. I am going to ask about this option at my dealer, but I doubt I can get it installed after purchase at this price. capture-20180821-145116.png
    Edit: I searched for TOYOTA OEM engine heater and found this on ebay. Toyota OEM Engine Block Heater SEE BODY FOR VEHICLE FIT | eBay It's only $54. So, how hard is it to install it DIY?
    #19 Salamander_King, Aug 21, 2018
  20. Spidey71
    Spidey71 Member
    60
    49
    Alberta, Canada
    2018 Prius Prime
    Ha! I guess it's $293.50 "difficult" to install. That seems steep for labor. If I can wrestle the car away from my wife I'll try and have a look under the hood and see if I can get a peek at the install. I'm wondering if the steep install price is due to removing the skid/protector plates under the engine?
