Block heater with break-away magnetic connector
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Ari, Oct 15, 2007.
  1. Ari
    Ari New Member
    165
    I've been wanting to install an EBH and also rig a magnetic plug. I'm sure most people are content to just plug in their EBH and then unplug it in the morning, but I would like to simplify things a little and be able to drive away without having to remove the cable. A magnetic plug would allow me to forget about the power cable in the mornings. I could have the system on a timer so it's not always burning power but I would otherwise leave it plugged in.
    At home I have a deep fryer and it has a 110V magnetic plug that will probably deliver 15 Amps. It's a safety device that reduces the chance of a kid tripping over the wire and pulling the fryer down from a countertop. That connector would be ideal for this EBH application! However, the spare parts available for these fryers only include the cable itself, not the other half of the connector:
    http://www.theconsumerlink.com/TFal/detail...SS%2D983927/100
    Anyone know of a source for similar magnetic plugs? It's also the same idea as the cable on Mac laptops, only bigger. I've searched online and come up with nothing except fryer parts, but there would be many uses for a plug like this.
    Thanks!
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    I don't, but I'd be interested if you find something.
  3. a priori
    a priori Canonus Curiosus
    3,083
    407
    23
    Chicagoland (West)
    Just to clarify: The break-away would attach to the male plug at the car's grill?
  4. efusco
    19,891
    1,192
    Nixa, MO
    <div class='quotetop'>QUOTE(a priori @ Oct 15 2007, 08:42 PM) [snapback]526118[/snapback]</div>
    I think you'd have to replace the male end with a separate piece made to mate with the female side. You'd probably have to modify your extension cord as well.
  5. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    wow, I wasn't even aware that breakaway plugs were available for
    120vac rather than just safe low-voltage. If you figure out who
    makes it for the fryers, please post it. Hmm, maybe some running
    around at the hubbell and eagle and leviton sites might turn up
    something..
    _H*
  6. jbeletti
    jbeletti Junior Member
    Chicago, IL
    Ari,
    Were you able to find out any more about the potential of creating a magnetic breakaway cord or connector for the Prius EBH?
    A week ago, my neighbor showed me his magnetic breakaway cord on his fondue pot. I was intrigued for sure
    Since then, I too have been researching various sorts of breakaway cords. I looked at more mechanical methods first. But I am fearful of the pulling force required for them and what that sort of stress does to the conductors. Even with a fixed receptacle under the bumper (vs. a dangling cord).
    Found some nasty truck fires where the fire investigation suggested that the cause may have been related to stressed insulation and/or the wire itself within the cords.
    I am just trying to prevent the inevitable when I back out of the garage after forgetting to unplug :eek:
    Jim
  7. Northbend08
    Northbend08 Arrrgh!
    Pacific Northwet
    The fire service uses outlets (inlets?) that use a spring to eject the extension cord when the ignition is switched on. While more complex than a magnetic connection, the parts are available.
    Here's one: Kussmaul Electronics Co., Inc. Super Auto Eject Data Sheet , though not a model I'm familiar with. The linked page says it is wired to the starter circuit, but the ones I've used are linked to the ignition, and you can hear the cord spring out of the ejector and strike the floor (or wall).
  8. jbeletti
    Chicago, IL
    Thanks for the link. Great products at Kussmaul. Not sure I'd want that big receptacle on my Prius but I may put one on my truck for a battery tender. I have a truck that sits 95% of the time and is used for towing an RV only. I could put one of those in the rear bumber (diamond plate aluminum and large enough).
    But I really like that auto-eject feature and will continue to research this. Not sure if anyone has seen the inside of their front bumper for any reason (crash repair etc). Wondering if it's packed with sensors for air bag deployment of if one of those receptacles could be put in from the back-side, say behind a hinged license plate bracket???
    I realize that this talk is sort of the "lazy man's way out" but it can also be a safety consideration on that one day a year I leave the house "stupid" for some reason.
    Jim
  9. oly_57mpg
    oly_57mpg New Member
    360
    Olympia, Portland, Seattle...
    Not to worry, eventually, one of the plugs going to the EBH will pull free. I've driven off [to work] and forgot to unplug the EBH a few times. Either the NEMA 5-15 plug from the car will pull out of the extension cord, or the extension cord will pull free from the outlet in the house! ;)
    Would you please measure the gap between your fry'ers magnetic plug? If it's 0.5 in, then that's a normal width for NEMA plugs. You could solder/glue some steel blades in a normal female plug and hope that the steel will hold the magnet in place... Or just allow the steel blades to bend out of the femal NEMA cord.
  10. Bob64
    1,540
    92
    Virginia
    Another possibility:
    The tension of the car backing out will damage the wiring of the EBH before the plug lets go.
  11. david81
    david81 New Member
    62
    NE Ohio
    I also would be very interested in something of this nature. I've seen them on my deep fryer, electric skillet and quite a few more newer appliances. I will soon be picking up an 08 Touring and I don't expect to see warm weather for a while now in NE Ohio. I have a wall outlet right in front of my garage bay that will be ideally suited for a block heater on a timer.
    I was thinking of installing a very low wattage red light that would be on anytime it is plugged in and placing that right in front of the car so that I can't miss it when backing out in the morning. I can easily see myself forgetting it otherwise.
    Anyone who manages to track down a simple solution will have my eternal gratitude.
    David
  12. efusco
    19,891
    1,192
    Nixa, MO
    Ditto
  13. alanh
    alanh Active Member
    1,175
    99
    Phoenix, AZ
    I can't find anyone that sells just the plug. You could try retrofitting one of these. The cord pulls out of the back of it. You could solder leads into the two holes meant to go to the fryer and attach a plug, and connect the EBH to that.
  14. EasyPlug
    EasyPlug New Member
    I'm working with a small start up building a magnetic breakaway device for block heaters (easyplug.ca). We are still in the process of building our prototype but I was wondering how much you guys would pay for a magnetic connector.
  15. efusco
    19,891
    1,192
    Nixa, MO
    Would vary depending upon what exactly you could supply, quality, workmanship, reliability, etc.
    The number that came off the top of my head was $20, maybe up to $30 if the product looked particularly good and had a really good install.
  16. FireEngineer
    FireEngineer Active Member
    1,247
    124
    SW-Side of Chicago, IL
    Well if you ever want it tested on a Prius, I could give you my opinion.
    Wayne
  17. hill
    8,173
    From the web site, it looks like the company doesn't actually make ANYplugs yet. Wonder how far out their time line is.
  18. Flying White Dutchman
    4,374
    313
    this would be nice for a plugin plug.. just drive away in the mornig after a charge
  19. Martin Thomas
    Martin Thomas New Member
    I realise that this is an old thread. I was not able to check easyplug. I assume the venture did not live up. However, I did discover magnoplug (sorry can't publish URL yet) which seems to be fairly recent. Oddly, their kickstart funding failed. Looks like they still have a good attitude and from their press release, they seem to be going ahead anyway. I'll certainly contribute if their create a new funding opportunity. :)
  20. Maggy Field
    Maggy Field Junior Member
    24
    Tennessee
    You could attach a 1/16" steel cable to the wall and to the body of the plug of the extension cord. Make the cable a couple of inches shorter than the cord. It will pull out the plug with no tension on the cord as you drive away.
    For discussion/educational purposes only. The usual caveats apply. This may be a stupid idea, check with U.L. laboratories, a competent engineer and anybody else you might need to before actually doing this. Blah blah blah.
