Block Heater
Discussion in 'Lexus Hybrids and EVs' started by subdewd, Dec 11, 2009.
  1. subdewd
    subdewd Junior Member
    Has anyone sourced an engine block heater. From what I've gathered they are only available from canadian dealers. Are they the same as the Hylander as stated?
  2. patsparks
    10,664
    567
    Adelaide South Australia
  3. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    Dewd,
    FWIW, there are non-make specific engine warmers such as this
    one that may work just fine in your situation:
    Wolverine Engine Oil Heaters
    Since there is no info in your avatar, can't tell if you can get one
    though.
  4. ken1784
    ken1784 SuperMID designer
    2,940
    1,359
    67
    Yokohama, JAPAN
  5. Danny
    Danny Admin/Founder
    7,093
    2,100
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    It's the same model for all Toyota products. Actually, up until this year, the "Prius" EBH came with Lexus install directions.
  6. markderail
    markderail I do 45 mins @ 3200 PSI
    2,260
    162
    Pierrefonds (Montreal) Quebec Canada
    I went today with the 400w Toyota EBH, instead of Wolverine (or similar) pad-based heater.
    Took my garage 1.5hr to install, 1hr less than the dealer.
    Theory being an EBH designed for the Prius will be better than any pad.
  7. FireEngineer
    FireEngineer Active Member
    1,247
    124
    SW-Side of Chicago, IL
    I haven't done a Lexus yet, but I'm willing to try.
    Wayne
  8. subdewd
    So there's a port milled into the block where the EBH goes? nice
    I'm in St.Louis. If I was closer to Chi. I'd take you up on the offer.
    I know you haven't done the Lexus but with the other installs
    was it necessary to drain the cooling system?
    Any chance you've got the Lexus instructions you could post?
    OT I ordered a "factory cd workshop manual" that's at the Post Office I'll pick up mon.
    Anyone familiar with it? Got off Flea Bay
  9. jayman
    jayman Senior Member
    13,439
    639
    Winnipeg Manitoba
    Apparently, Phillips-Temro now makes the correct cartridge style heater for the 2004-2009 Prius
    Engine Block Heaters
    You can download their catalog and verify the part number. If you live in the EU, then Defa of Norway also makes the correct heater
  10. FireEngineer
    1,247
    124
    Your "factory workshop manual" won't have any information on the block heater if it is like any official Toyota manuals. No drain down is needed. And I'd be happy to go down to St. Louis, just a day trip for me.
    Wayne
  11. subdewd
    Thanks for the offer I pretty sure i can handle it. i've been working on vehicles since before they had seatbelt and have managed to keep up with the technology.
    I work as an electronic tech for the USPS repairing their automation equipment.
    Got the cd yesterday extremely comprehensive. Good wiring etc, unfortunatly i need a bigger widescreen monitor to view all the info in a size I can make out!
  12. hill
    8,068
    Probably too late to mention, but evan did an excelent play by play presentation on his hyhi ... and it's virtually the same as our 400h Lexus, if you need more detail. Both suv's are built on the camry platform, so as stated in threads above, there's lots of interchangability
