Blocking Grill - safe operating tems
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Kaibz, Feb 18, 2008.
  1. Kaibz
    Kaibz New Member
    Maryland
    After reading several detailed posts I decided to go ahead and block my grill. I have completely blocked the upper grill and about 75% of the lower grill. I started getting better mileage immediately. Early morning commute went from 49 – 52 mpg to 54 – 58 pg, an increase of about 10% (a 14 mile commute). I was extremely surprised that such a simple (20 minutes to install, and I am NOT mechanically inclined) and inexpensive ($3.50 total for pipe insulation and black zip ties) mod could have such a significant impact.
    I am able to monitor engine temps via my Scangauge II, however, I’m not sure what temp ranges are best for fuel economy and at what temp should I start worrying about overheating? Sorry if this is a stupid question but any help would be greatly appreciated!
    1) What temp range is best for overall fuel economy? At what point does an engine temperature drop start having a significant or noticeable effect on gas mileage?
    2) In general, what is the highest engine temp (or range) that can safely be maintained. At what engine temperature should you start unblocking the grill?
  2. icarus
    icarus Senior Member
    4,884
    976
    earth
    Do a search for "grill blocking" on this site. There are tons of threads ont he subject. Save the bandwith and read what is already posted. (It seems that we have to keep reinventing the wheel, rather than searching.
    Icarus
  3. Bob64
    1,540
    92
    Virginia
    1) At least 70c.
    2) If you start going at or above 95c, then consider removing a slit. If you hit 110, start worrying and perhaps slow down a bit... If you hit 130c, the coolant is probably boiling at this point... You should really stop and unblock your grill at this point, as both your cooling fans are probably at full blast.
  4. icarus
    4,884
    976
    earth
    130c is ~260f. I think that is too hot to run consistently. 110c is about the max that I would like to see on an ongoing basis.
    Not withstanding my above comment that we have been there done that: The best mileage seems to come ~190f, with not much gain above that. The thermostat BEGINS to open ~185 and is FULLY open ~205.
    When I see temps above 205f for a bit, I turn on the heat climbing a hill, or if it stays that warm, I'll pull a grill plug.
    Icarus
    Another issue to consider is inverter/electric motor temp, that is NOT displayed on a scan gauge! Once again, a search will give you some additional information on that subject.
  5. Kaibz
    Kaibz New Member
    Maryland
    I have read the many threads on the subject, that is in fact how I learned about grill blocking in the first place and where I learned how to do it.
    Since you seem to know so much about what is on the site, why don't you try pointing me to the "many" threads that discuss the exact question I asked? I have read hundreds of responses and don't recall any talking about optimum temperatures and/or dangerious temperatures.
    The thread that just appeared ahead of this does not address both issues, not does it state what the safe operating tems are, just what this one driver does not want to exceed.
    Jack A#$
  6. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    {moderator hat on}
    Watch the attitude. That's not welcome here. Not sure what sites you've posted on before, but we keep things civil here. If you're not willing or able to do that you'll need to find somewhere else to participate. {moderator hat off}
    Now, the search feature of PC is not great, but Google is.
    If you'll time your key words into the google search window then enter site: priuschat.com it will search only this site and you'll find lots of replies.
    Here are a few I found with about 30 seconds of googling:
    http://priuschat.com/forums/prius-main-forum/40732-can-i-block-my-grill-now.html
    http://priuschat.com/forums/knowled...ion/39901-grill-blocking-summary-article.html
    http://priuschat.com/forums/prius-modifications/40206-grill-blocking-caution.html
  7. diamondlarry
    diamondlarry EPA MPG #'s killer
    559
    Elkhart, IN
    You would want to keep the coolant below the temp at which the cooling fan comes on. The increased electrical draw would pretty much cancel out any gains from a warmer engine.
  8. icarus
    4,884
    976
    earth
    Kaibz,
    I'm sorry if I got your dander up. My point is thus. With no malice towards the moderators who do it all on a gratis basis: This site suffers from our own laziness. I do indeed include myself in that group. It is often easier to post important question and rely on the kindness of member to answer it, than it is to do at least a quick search to find out if the answer already exists on this forum. I co-moderate a site much like this one, and we strive to keep the number of duplicate posts to a minimum so that it is easier for all to use. It takes time and effort, but that effort is rewarded by making the site very good at getting the information out without having to wade through many, many duplicate and semi-duplicate posts.
    I know for a fact that often I won't respond to a question, EVEN if I think I can add useful information because I know that the answer (probably answered by someone more knowlegable than me!) already exists on some other thread(s)
    I am just a member here, and as such I have little or no say in how it is run. What I do know is that the good Danny pays for band width and storage, so filling it up with redundancy doesn't make sense, especially when there are often better answers posted elsewhere.
    As to not doing the search for you,,, Sometimes I too have time constraints. I would always like to lead people in the proper direction by I can't always.
    As for being called names,,,call me anything you like, just don't call me late for dinner!
    Icarus
    Ps. thanks Evan for doing what I know is a thankless job!
  9. Kaibz
    Kaibz New Member
    Maryland
    No problem and I realize that while grill blocking has been discussed on this site extensively, the specific issue asked has not been the actual “subject†of a separate thread. One or two persons might have tangentially commented safe operating temperatures, three or four pages into a general grill blocking thread, but I was hoping to see a more focused discussion specifically relating to the safe AND optimal operating temperatures – which several persons have already done (thank you very much).
    I just thought it was a bit out of place and inappropriate for a “senior member†to 1) tell me I had not done a proper search, 2) that I was reinventing the wheel, and 3) that I was wasting valuable space. If he thought the specific issue had been discussed then the appropriate action would have been simply to post a link to the applicable discussion – or to simply give the answer.
    I haven’t finished looking but have not yet found the tread that he was discussing, none have addressed optimal and safe operating temperatures.
    Instead of wasting more space with useless commentary, maybe the “senior member†could point me in the right direction.
    Thanks for the search advice, that is extremely useful, I didn’t know you could use Google in that manner – thanks again!
  10. efusco
    19,891
    1,192
    Nixa, MO
    If you'll read through this thread I think you'll find all the information you're looking for. It's not all in one precise spot, but optimal temps, maximum temps all the things you seem to be looking for are discussed at length, debated and some pretty good conclusions are reached.
  11. Kaibz
    Kaibz New Member
    Maryland
    Although it is a great thread, and I did read it prior to blocking my grill, it does not answer all of my questions (and please see post #43 in that thread, that reader is asking something different as well). I believe that much of the “senior members†concerns stem from a fundamental misunderstanding of the questions posed. Had the question simply been, “what temperature do I want to be careful not to exceedâ€, the hostility evidenced by his unfortunate post might have been justified. I think a restatement of the questions might help clear up some of the confusion,
    1) What temp range is best for overall fuel economy? At what point does an engine temperature drop start having a significant or noticeable effect on gas mileage?2) In general, what is the highest engine temp (or range) that can safely be maintained. At what engine temperature should you start unblocking the grill?
    The thread does a good job of answering the second two questions (under “2)â€), regarding the upper limits of the engine’s heat tolerances, but does not in any way address the first two questions (under "1)"),
    What temp range is best for overall fuel economy and at what point does an engine temp drop start having a significant or noticeable “adverse†effect on gas mileage?
  12. icarus
    4,884
    976
    earth
    I think the good Doctor has steered you in the right direction, as he is the most "senior" (No offense Evan!) poster, I will follow his advice.
    I don't think there is any "real" answer. The design of the car gives us the clues however. Since the T-stat starts to open ~185f, and is fully open ~205f I would logically assume that Toyota's engineers base their design on those specs. Since the car is designed to be a high efficiency car, I would therefore assume that that is the range that give it the best balance between efficiency and longevity.
    Thats my story and I'm stickin' to it.
    Icarus
  13. Kaibz
    Kaibz New Member
    Maryland
    That is extremely helpful, thank you very much! I will shoot to maintain the temp somewhere in that range, I'm generally well below - so might need to block my entire lower grill.
  14. icarus
    4,884
    976
    earth
    You'll find that in cold weather (below 40f) it is very hard to GET 185f if you are on short hauls. It takes us almost 20 miles, 6 @ 50mph, 12 @ 60mph to get there from a starting temp of ~75f.
    Icarus
  15. Bob64
    1,540
    92
    Virginia
    From the above, it can be said that the most efficient temp range is 70c to 95c.
    70c (158f) because this is the temp where your able to enter "stage 4" mode of prius operation.
    95c (203f) because your radiator fans will probably start turning on once you go above it, based on ken's post.
    110c (230f) is probably the "Better unblock your grill or start slowing down" point since I THINK the radiator fans start to turn on full blast around this temp or at 104c (220f).
    130c (266f) is probably the "Holy smoking engine! It's about to blow! I gotta stop and unblock NOW!!" point, but I have no basis for this conclusion other then coolant starting to boil at this temp.
    Either way, I'd rather not tempt fate and stress the limits of the prius by running above 100c for any continuous period of time.
  16. Flying White Dutchman
    4,374
    313
    and you do not use the gril block yet or is this with the gril block installed?
  17. ksstathead
    ksstathead Active Member
    1,244
    244
    Kansas
    Also, note that the ICE will restart if coolant drops to 63C and run until 73C reached again, thus hurting mileage. I believe these temps are needed more on the emissions side than for mileage, but the Prius looks to control emissions #1, so Prius mileage is linked to emissions criteria.
  18. Kaibz
    Kaibz New Member
    Maryland
    Thank you very much for the great response!
    Those are some impressive numbers, 60+ mpg lifetime - I have much to learn (I have 1,200 total miles and only averaging about 54 mpg thus far, but all winter drving).
  19. sugar land dave
    137
    houston
    Grille-blocking is an important tool in the mpg toolbox. Sythetic oil and tire pressure are two others. Learning new driving styles also helps.
  20. David Beale
    David Beale Senior Member
    5,963
    1,983
    Edmonton Alberta
    There is lots of misunderstanding on this topic.
    First, in general, best MPG or most efficient operation is at the highest temp the engine will run without damage. It's a heat engine. They work best at the highest temps they can reliably operate at. I haven't calculated the temp at which the "stock" coolant boils, but it should be around 130C. I would start to worry at 115C. With both grills blocked I have seen 110C at 20C ambient on the highway (worst case). In the city at 20C ambient the coolant was running around 95C.
    Second, once the thermostat is fully open (around 85C) you are still no where near the max. capability of the cooling system. The two rad fans don't even start running until the coolant gets over 100C. Energy transport out of the rad is directly proportional to the temp difference between the coolant and ambient. Until the fans start. Then you can transport a lot more energy out of the coolant. I would start to worry when both fans are running at full speed.
    With both grills blocked and ambient at -30C Pearl's coolant will not get over 70C, meaning the rad is not really being used (though there is some flow through it via the bypass).
    Remember the car is designed to operate without overheating in Texas/Arizona/Nevada in summer, where ambient temps can reach 50C and you would also be dumping the energy from the interior via the A/C into the coolant (radiatively/convectively as the A/C rad is just in front of the coolant rad).
    I think there is a lot of "headroom" in the cooling system.
    There is, however, one area I WOULD be worried about. That is the inverter coolant. As posted above, we can't see the inverter coolant temps with the Scangauge. The inverter is built with solid state devices, and they don't like high temps (their power handling capability drops linearly with temp increase). So it would be "good practice" to be conservative with the cooling of the inverter. Remove the upper grill blocking before you would normally remove grill blocking for the engine coolant.
    My grill blocking will be removed when ambient temps are above 10C.
