blocking the door lock button which sends the electrical signal to my dashboard 2 avoid door beepin
Discussion in 'Prius c Main Forum' started by CARSFAN4, Jun 15, 2023.
  1. CARSFAN4
    CARSFAN4 Junior Member
    23
    Los Angeles
    2015 Prius c
    After an accident my 2015 Prius c front passenger door cannot be locked completely. So I need to apply pressure on the door frame post button which sends the electrical signal of unlocked door to my dashboard. I don't want to hear that high tone beeping. It is too distracting.
    49,488
    pull off the interior doorpanel and see if disconnecting the wires helps
  3. ChapmanF
    15,614
    The button isn't inside the door, it's in the body pillar where the door closes and pushes on it.
    You can just take the pillar trim off and disconnect the wiring from the button.
