Blower motor maybe, but code B1421?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by GreenMeanie, Jan 25, 2026 at 11:44 PM.
  1. GreenMeanie
    GreenMeanie Junior Member
    47
    My 2006 with 113k is not putting out any air from the vents at all. Neither heat nor cold nor defrost. It was making strange sounds a couple of weeks ago, and now I realize that nothing at all is coming out, no matter what the temperature is set to. Code B1421 comes up, but it says that's to do with the sun sensor. To me, it seems like the blower won't blow anything. Not sure how that has anything to do with the sun sensor. Thoughts?
  2. ChapmanF
    18,344
    Two different things. You have some problem with your blower and no code for it (that's not shocking, even modern cars with obd still can have things go wrong that don't set codes), and, unrelated to that, you have B1421.
    B1421 isn't quite any 'trouble' code really, just a tool for you to know whether the dash solar sensor works. If you have B1421 in the dark or the shade, and you don't have it in bright sun, the sensor works.
  3. GreenMeanie
    47
    Yeah, I was wondering if the blower motor would actually throw a code. But does it sound to you like the blower motor is the problem? Figuring out where to go from here. I'm not going to worry about the sensor, since it threw that code before and it never gave me a problem up until this blower motor thing.
