Blowing headlights on a frequent basis
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by btse6, Jul 15, 2013.
  1. btse6
    btse6 Junior Member
    Pacific Northwest
    2009 Prius with 115,000 miles. I've had to replace one or other of my headlight bulbs four times in the past six months. This is becoming a real PITA. Is there a known cause (and fix)?
  2. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
  3. Rich12
    Rich12 Member
    176
    29
    You're not putting halogens in a car made for HIDs are you...?
  4. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    Also its stated on most packaging and instructions, but you're not supposed to touch the bulbs when you're installing or handling them. The oils from your hands will create a hot spot on the bulb surface that can lead to early bulb failure.
    You can clean the bulbs of deposits and oils using common rubbing alcohol.
    SCH-I535
  5. btse6
    btse6 Junior Member
    Pacific Northwest
    Thanks for the tips! I'm unable to contort my aging arms/wrists/fingers well enough to get in there and replace them myself, so I have my local friendly garage do it. But I will check the items you all have mentioned the next time one blows, and make sure they don't make these possible/probable mistakes.
  6. xliderider
    7,869
    3,116
    Honolulu, HI
    Ah, a friendly mechanic type person is the bulb installer.
    Just the type of person with fingers covered with a permanent film of automotive oil and grease. ;)
    SCH-I535
