Blown head gasket, bent #2 connecting rod, weighing options
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by bptahiti, Apr 16, 2026.
  1. bptahiti
    bptahiti New Member
    Virginia
    2013 Prius 2, 320K miles, mostly highway.
    Short version: In the middle of replacing a head gasket, and found the symptoms of a bent rod #2, and trying to decide what to do.
    Longer version:
    Had some death rattle episodes during one short drive (less than 10 miles), and had a check engine light by the time I got home. P0302 code. Decided to replace spark plugs in the hopes that could be it, since it has probably been 100K since those were done. Seemed better on first crank up, took it around the neighborhood to test it out, seemed OK. Was going to take it on short trip as another test, bad rattle, check engine light and P0303. Dove into head gasket replacement research and supply gathering. Fumbled my way down to the head gasket, found cylinder 2 with coolant in it, blown head gasket. Cranked it around and piston 2 comes up a little short of piston 3, with no wiggle when I push on the piston, where there is wiggle on the other 3 - from what I have seen/read, that should confirm #2 rod is bent. So, my options seem to be:
    1. Slap the new head gasket in and hope for the best? Is this at all reasonable? Can it survive with a bent rod? It seems to spin ok without obvious binding, but would there be further tests to see just how bad it is on the spectrum of bent rods? Or would it be a ticking time bomb no matter what?
    2. Try to tackle the rod replacement myself. What am I in for here? A couple posts seem to suggest it MIGHT be possible to replace #2 rod with the engine in place, but sounds iffy, and may be better off trying to pull the engine? I don't have a hoist or stand, so that is an issue I would have to solve. How much more work is the rod replacement past the point of getting to the head gasket? More specialized tools needed?
    3. Switch from repair mode to a JDM or other engine swap? Every post I see where this comes up there seems to be the side that says you have no idea what mileage or condition you are really getting and no meaningful warranty, and the side that says "why are you going through all that trouble when you could just swap the engine for X$? Still have the issue of no hoist, but similar question from option 2- how hard is the engine swap compared to the head gasket?
    4. Hand it over to a pro. Assuming I would not likely get a discount on the work for handing them the car with the head off compared to them starting from scratch, this seems to me like out of the realm of what it would be reasonable to spend on a car with 320K miles, but what would you expect to spend for a professional engine swap?
    5. Bid the old girl farewell and start searching for her replacement. She has served me well for years. Would be sad to see her go and add a car payment to the budget, but I also need a reliable vehicle in short order.
    Am I missing an option? Is there a clear winner amongst them?
  2. douglasjre
    douglasjre Senior Member
    2,216
    741
    Null, NL
    I would get a used JDM motor from Fleabay
  3. frodoz737
    frodoz737 Top Wrench
    4,736
    2,526
    33
    Even if you choose to repair or replace the engine, the reality is your car still has 320,000 miles on the clock.
    #3 frodoz737, Apr 17, 2026
    Brian1954 likes this.
  4. Mendel Leisk
    42,052
    Consider a new short block?
  5. WICruiser
    WICruiser New Member
    23
    WI
    320k miles puts it into the "time to replace it' category. Anything can be fixed but if you put in a different engine you still have a 13 year old car with very high miles waiting for the next failure.
  6. Mendel Leisk
    42,052
    Maybe. @NutzAboutBolts and @ASRDogman are both over 300k miles IIRC, and have done recent head gasket replacement. They both are/were professional mechanics I believe.
  7. bptahiti
    bptahiti New Member
    Virginia
    I haven't come across this option yet. How would that compare in terms of pros/cons to a JDM?
    Assuming I decided to sort out the engine, what would be the next big thing on the horizon? High voltage battery - how long does that reasonably last?
  8. Tombukt2
    Tombukt2 Senior Member
    13,597
    2,457
    Durham NC
    Dust to dust
  9. cdherman
    cdherman Member
    61
    25
    Kansas City
    I am wondering what bptahiti did. Perhaps he will tell us.
    I would disagree that the whole vehicle is done. Maybe but..... I think it would deserve a used JDM engine IF:
    -- does not have rust or other damage
    -- interior is in good shape
    -- transmission has been cared for (meaning fluid changed once or twice at least)
    -- traction battery SOH is also kind of a variable. If its the original traction battery, then a negative, but if its had the traction battery rebuilt or replaced, then that also would speak for fixing it up.
    Unless the OP lives in an area blessed with one of the dedicated Prius shops that do JDM engine swaps regularly, that costs a fair bit too, unless going it ones self......
    These days the # of miles on a vehicle does not always paint the right picture. Someone driving a vehicle as a courier may put a lot of miles on a vehicle, but with no passengers and regular maintenance, the vehicle may be amazingly well preserved.
  10. rjparker
    rjparker Tu Humilde Sirviente
    10,675
    6,706
    Texas Hill Country
    Replacing the car is the best move if reliability is of any concern assuming you have the funds or decent income and credit.
    The alternatives are replacement engine or replacement car.
    Repairing it is more work than installing a jdm and you get a newer water pump, intake, head, rotating parts, injectors and more.
    A pro rebuilt engine replacement (not yours) might make sense if the car is 200k mile or less and you seriously want ten more years. A short block with labor is around $8k and makes no sense on a 320k car. Even then you are looking at a hybrid battery and brake booster very soon to make ten years.
    A JDM engine can be as new as a 2021. To get the best one you should inspect before purchase. Around here we have a jdm distributor and a hydrid shop that has done many hundreds with great success, most without oil burning reflecting advertised low mileage.
  11. cdherman
    cdherman Member
    61
    25
    Kansas City
    Yeah, me personally, I'd toss the Gen 3, but not everyone feels that way. For me, the creature comforts of newer stuff, like adaptive cruise, lane centering, emergency braking, all make a newer vehicle a better option. But some don't have those funds.........
