Blown head gasket prius c
Discussion in 'Newbie Forum' started by pattilaw, Aug 29, 2023.
  1. pattilaw
    pattilaw Junior Member
    190k. 2013 Prius c.
    Just did rear hub bearings, front brakes, shocks, sway links and tie rod inner and out. Fixed a coolant leak.
    822F5259-39C4-41AF-BBA9-79284557ED11.jpeg Put in Maintenance mode, performed Pressure test to check my work and the pressure rose fairly rapidly. Did a reld chemical test and it’s green.
    Blown head gasket?
  2. pattilaw
    Lesson learned, fix the coolant leak first?
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,803
    2017 Prius c
    Maybe.
    But that is not common with the C engines.
    I certainly would NOT start tearing the engine down
    based only on that one test.
    Doug McC likes this.
  4. pattilaw
    Well, last effort Before taking it to the shop for them to find the leak, I put a new radiator cap. Drove around for a few hundred miles and not losing coolant!
    I find it hard to believe my luck could be so good, and will keep an eye on it. : )
