Blue arrows VS. Yellow arrows?? Whats the difference?
Discussion in 'Gen 2 Prius Fuel Economy' started by freshmtt, May 15, 2008.
  1. freshmtt
    freshmtt Dachshund Addict
    532
    Chicago Suburbs
    I read in someone's post about Pulse and Glide and they said that the glide mode should be when there are no arrows on the display, but my question is what is the difference if there are no arrows compared to either blue arrows only or yellow arrows only.
    All three of these, NO Arrows, BLUE Arrows, and YELLOW Arrows all show that you are getting 99.9 MPG.
    And if your main goal is to increase MPG why should is matter if you have only NO Arrows? According to the display you are getting the same MPG as if you had blue arrows or yellow arrows??
    Can someone explain if it really matters and why??
  2. okiebutnotfrommuskogee
    okiebutnotfrommuskogee Senior Member
    1,813
    Tulsa, OK
    Yellow arrows show that you are using battery power to help move car. Sooner or later that energy has to be replaced. Some of it will come from regeneration when stopping, but some of it has to come from the engine driving a motor/generator.
    Green arrows indicate regenerated energy flowing to battery. That is a good thing if you have to slow down anyway, but if you are trying to get maximum coast, that regeneration will slow you down a little.
    No arrows show that you are really coasting, almost like old fashion free wheeling. This gets you the most for your pulse and glide action. If you have green arrows and press slightly on the go peddle to make all the arrows go away you will actually feel the car speed up a little because it is rolling more easily.
    Since this pulse and glide won't work above about 41mph, I usually let up on the gas when the speedometer gets to 40mph and let the car slow down a couple of miles per hour with green arrows then go back into no arrows glide.
    Hope this helps.
  3. Sheepdog
    Sheepdog C'Mere Sheepie!
    1,125
    Sanford FLorida
    I love P&G but it slows down too fast to suit me! 40 to like 29 or the like seem to take no time at all. at the end of my day I like to travel at speeds less than that and on battery only knowing it will charge the next day anyway to heat up.
    I usually do 50mpg but today I got to 57 playing with my SGII. neat toy!
  4. dogfriend
    7,512
    1,185
    Carmichael, CA
    There are actually 3 colors of arrows:
    Orange arrows show mechanical energy transferred from the ICE to power the wheels or to turn the generator (MG1).
    Yellow arrows show electrical energy transferred to power the car or to charge the battery (often both at the same time)
    Green arrows show electrical energy that is from regeneration and would normally be lost as heat when braking or powertrain loss when coasting.
  5. NoMoShocks
    NoMoShocks Electrical Engineer
    1,292
    82
    Camas, WA
    Another important thing to note is that 99.9 MPG is the maximum display, so it could be 99.9, 345, 107, 220, infinity, etc. Therefore, when you see the 99.9 MPG with yellow arrows and then again with blue arrows, don't think the car is getting 99.9 MPG. If you get a Scan Gauge, you can read up to 999 MPG.
  6. bbald123
    bbald123 Thermodynamics Law Enforcement
    386
    271
    Harrisburg, PA
    This means you aren't hitting the glide quite right. You are getting regenerative braking.
    Change to the energy flow display and practice "no arrows" glides until you can do it without referring to the display. With flat or very slightly downhill I can glide miles, literally, at 99.9 MPG.
  7. acdii
    acdii Active Member
    1,124
    131
    I found the TCH P&G's much easier than the Prius. The pedal on our Prius was too sensitive, but the 09 TCH seems to be much easier to get it to glide. So far I am up to 38 MPG mixed city highway. If I can get on a very long stretch of open 55MPH road with light traffic I can get it over 42 MPG.
