Blue Tooth with Iphone No folder control
Discussion in 'Prius c Audio and Electronics' started by Lionsfan, Sep 24, 2012.
  1. Lionsfan
    Lionsfan Junior Member
    26
    Montrose, MI
    2015 Prius c
    I use my iphone via bluetooth to play my music and podcasts. If it's wireless I have no control over the folders through the audio controls. I have to manually go through the folders on my phone to cue up what I want to play. Which seems counter productive. I can skip forward to the next song and pause/play but that's it. If I have it plugged in to the USB I can control the folders when I am in ipod mode. But it wont let me play it. I then have to switch to BTA to play it. Then back to ipod if I want a different folder or playlist.
    Does anyone else have this issue?
  2. photogrl13
    photogrl13 Member
    115
    47
    59
    Columbus, Ohio
    It is the same with my iPhone 4. I use Bluetooth only for tune in radio, so it doesn't bother me much. I use the iPod cable when I want more control over folders. I generally don't drive far enough to be bothered by the limitation.
  3. Surrylic
    Surrylic Junior Member
    122
    Winchester VA
    I had an android phone for about five months while I have had this car, and now I have an iPhone 5. Both have the same issue you mentioned, you can see the song title and artist but not browse. Sorry :/
  4. MBRGuru
    MBRGuru Member
    255
    26
    iPhone 5 (iOS 6) supports Bluetooth browsing, but it looks like it's only working on the HDD system right now.
  5. photogrl13
    photogrl13 Member
    115
    47
    59
    Columbus, Ohio
    I updated to iOS 6. I will try again tomorrow to see if things changed for me.
  6. photogrl13
    photogrl13 Member
    115
    47
    59
    Columbus, Ohio
    No control with ios6 on an iPhone 4.
  7. RJphxC
    RJphxC New Member
    22
    Glendale, Arizona
    I think this is typical for bluetooth connections in cars. If there's a way to make this work then great but I'm skeptical.
    *first post - first day driving my new C* :)
  8. Gronos
    Gronos New Member
    Buffalo, New York
    I have an iPod touch 5th gen and the folder commands on the dashboard don't work with this either. Toyota should do a software upgrade to fix this.
  9. Rob.au
    Rob.au Active Member
    960
    441
    Sydney, Australia
    i-Tech
    Same story on the Australian audio with iOS 6 and iPhone 4S.
    Since the Google Maps app came out I finally bit the bullet and upgraded the iOS. At one stage Bluetooth all but stopped working - it would play audio but had NO control of the phone at all (not even play/pause)... tried everything, unpaired, repaired, power cycled both the phone and the car and eventually gave up and went into the shopping centre I'd parked at. Came back out, stepped into the car and voila - everything was working (ie. play/pause, skip, song information received by audio system but still no folder control via Bluetooth) AND the car can now both alert me to text messages received and read them to me.
