bluetooh problems
Discussion in 'Gen 2 Prius Audio and Electronics' started by shw, Dec 5, 2009.
  1. shw
    shw New Member
    nc
    Recently my bluetooth stopped working right. When I start the car, the screen says a call is in process. However my Blackberry Storm isn't in use. If I try to use my phone, it is silent and doesn't connect to the car via bluetooth. Any ideas?!! Thanks!
  2. PriusRos
    PriusRos A Fairly Senior Member - 2016 Prius Owner
    1,973
    218
    Rockville, MD
    I can't help you much, but I have a similar problem sometimes. I have an LG Dare (since you have a Storm, I assume you are on Verizon, too). It generally works, but sometimes when I try to make a call through voice commands, it will let me get all the way to confirming the person I want to call, and then when I hit the off-hook button or say Dial, it will tell me the phone is busy.
    I think it is usually resolved by powering off the phone and restarting it. Also, make sure your phone is fully charged.
  3. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    Try deleting the phone from the system and then re-pair it.
  4. kent_gd
    kent_gd New Member
    Pennsylvania
    I'm also having bluetooth problems. When I turn on my 2004 Prius and push the info button, the telephone button simply isn't on the touch screen. I tried turning the bluetooth on my phone on when I started the car and turning it off. I tried to change settings.
    One time, I didn't do anything differently and the telephone button showed up, but when I tried to pair it my iPhone couldn't find the prius. It just said searching for devices and didn't find it for a good 10 minutes.
