bluetooth, blackberry 7290 and the 2005 Prius
Discussion in 'Gen 2 Prius Main Forum' started by frank_prius, Feb 13, 2007.
  1. frank_prius
    frank_prius New Member
    I got it to the point of pairing the 7290 and the Prius but havent made much progress thereafter.
    When trying the "connect" on the 7290 , it always fails.
    Has anyone got this past this point ? Appreciate any tips or steps.
  2. stevelawrence
    stevelawrence Junior Member
    I see the 7290 is the black 'origional' one?
    Yes - I've gotten mine paired.
    I had to :
    Goto the phone screen, and hit the button to register.
    Goto my Blackberry, and select the 'Bluetooth' options, and then 'Add/Pair Device'. It'll find something called um.. 'Hands Free'.
    Connect to it, it'll ask you for the password from the car's LCD - Which I believe defaults to 1111.
    Do the connect, the car says 'Found'.
    Then register that phone under Phone 1 (It'll do this automatically) and hit the 'Call' button, slap your number in, and Bob's your uncle.
    I had a bit of a headscratch moment when I thought it was registered, but it wasn't because I hadn't gotten the BlackBerry to 'connect' to the car, but the Car had found the BlackBerry.. Or something. A couple of minutes fiddling on both ends eventually got it working fine, and I was able to make a call from my car, using my Blackberry, to my house's landline.
    Steve.
  3. frank_prius
    Mucho thanks - that worked !!!
