Bluetooth connection
Discussion in 'Gen 2 Prius Main Forum' started by Surfer, Jan 17, 2006.
  1. Surfer
    Surfer New Member
    It seems that everytime I turn of my car my phone connection is dropped. Then, when I start up the car I must reconnect using the display. Is there a way to have the connection made automatically without having to reconnect it everytime?
    Thanks
    http://artkauai.com
  2. DaveSheremata
    DaveSheremata New Member
    249
    Arlington, Virginia
    Hey Surfer.
    I don't have my prius - have to wait till Saturday or Sunday - so I can't be very specific. However, normally you have to "pair" bluetooth devices and set a checkbox or something similar on your phone to indicate that your prius is a "trusted" device. Which phone is it? Perhaps that little piece of information will draw the ideas of someone else with the same phone and they could give you *very* specific instructions.
    Good luck,
    Dave
  3. 1playwonder
    1playwonder Junior Member
    Modesto, CA
    I have the bluetooth connection on my prius and it works fine. My phone is a Nokia 6256i. Once I paired my phone to the car it automatically connects whenever I start my car. I didn't check the "trusted list" before connecting my phone, but I suggest looking there first.
  4. iluvmacs
    iluvmacs Member
    280
    104
    Madison, WI, USA
    If they weren't paired, they wouldn't be connecting at all.
  5. Wayne
    Wayne Active Member
    723
    27
    Fort Wayne, IN
    Surfer, state what phone you are using.
  6. Surfer
    Surfer New Member
    I have a motorola razr.... Any ideas?
  7. aaf709
    3,862
    2022 Prius Prime
    Who is your provider?
    I have an e815 with Verizon. I have the BT turned off most of the time (no BT earphone), but it pairs right away when I turn it on.
  8. tag
    tag Senior Member
    2,526
    Chicago
    Just a shot in the dark:
    Did you complete the initial setup procedure (i.e. "Add phone")?
    In your Razr's BT setup menu, do you have Bluetooth power set to "On"?
  9. Dylan
    Dylan New Member
    23
    I don't remember the menu sequence to get there, but there is an option for Bluetooth autoconnect. I'm guessing you don't have this on.
  10. kkister1492
    kkister1492 New Member
    355
    Fremont, CA
    I've got the RAZR with Cingular and once I did the initial setup the Prius looks for it everytime I start the car. That's how I know when I've left my phone in the charger in the house before I leave. Quite handy!
  11. kkister1492
    355
    Fremont, CA
    BTW, I've got to say that the bluetooth connection to my Prius is just the greatest thing!! I love just touching the button to make or take a call and no stiff neck from trying to hold the phone and drive or whatever. The RAZR is one of the best Christmas presents I ever got!!
  12. DocToss
    DocToss Junior Member
    69
    Cordova, TN
    I believe on the 06 there is a setting to connect automatically when the engine turns on or not.
  13. Rocketeir
    Rocketeir New Member
    28
    Edgewater, Florida
    I have an 06 and you can set it up to autoconnect blue tooth at power up. It works seamlessly with my Siemens SX66. I am having trouble with figuring out the voice recognition though. It is not working the way I think it should. Gotta go search the forum!
    Regards,
    Steve
  14. Surfer
    Surfer New Member
    Thanks Steve I did not push autoconnect but rather just pressed the connect button each time. Now the razr connects when we push the start button automatically...
    Thanks everyone else
