bluetooth integration kit
Discussion in 'Gen 2 Prius Audio and Electronics' started by jukeboy, Nov 26, 2007.
  1. jukeboy
    jukeboy New Member
    132
    SGV, SoCal
    Circuit City had the Parrot 3000CK for the black friday special of $99.99 installed excluding additional parts such as a wiring harness, and so I had to purchase the Metra BT-1761 integration kit for 87-05 Toyotas, but it appears it doesn't work for the Prius according to Crutchfield.com, which obviously has a better price too.
    I already had some reservations after picking it up prior to checking Crutchfield.com, so I'm going back to check with CC to see if I could return it for a full refund should it found not to be compatible after opening it. does anyone have advice to offer?
  2. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    There is an earlier post on here or PriusOnLine on the same topic with the same results. Nope, it won't work. If you didn't purchase a Prius with bluetooth capability, you're out of luck, unless someone invents a new gadget.
  3. omgitsroy326
    omgitsroy326 New Member
    267
    Los Angeles
    <div class='quotetop'>QUOTE(firepa63 @ Nov 26 2007, 10:49 AM) [snapback]544235[/snapback]</div>
    why doesn't it work?
    I have the parrot 3200 and i have it working in my car right now
  4. blamy
    blamy Member
    380
    Central Florida
    [attachmentid=12627]Motorola makes a Bluetooth kit. I believe it is called the IHS1000 or something like that. Here is a picture of an older model Bluetooth kit from them. I use one in my Prius and it works very well.
  5. tedmarshall
    tedmarshall New Member
    25
    San Jose, CA
    <div class='quotetop'>QUOTE(jukeboy @ Nov 26 2007, 05:34 AM) [snapback]544203[/snapback]</div>
    Check out Quick Connect (formerly parrotkit.com). I had a 3000CK with their harness in my previous car (Mazda 6) and was very happy with it.
  6. GeoGeek
    GeoGeek Member
    360
    31
    Auburndale, FL
    The Metra BT-1761 is just a kit to allow you to tap into the factory radio wiring without cutting.
    I'm currently using the 1760 & 1761 in combination to avoid cutting the factory wires so I can
    feed an aftermarket audio system.
    I know that they are compatible with the 2006 non-JBL prius, but I can't say for sure for the 2008....although I don't believe much has changed.
    The store wants to use the kit to tap in to the factory speaker wires.
    The Parrot kit won't integrate with the MFD or anything, but the sound will come over your speakers and
    it will mute the stereo when you receive or make a call.
    Hope this helps.
