Bluetooth/Navigation not working once outside temperature is high
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by PriusIndia, Jul 18, 2019.
  1. PriusIndia
    PriusIndia Junior Member
    24
    Earth
    It seems peculiar issue. My 2012 Prius is behaving oddly. At the start of the summer when outside weather started to get hot, components on the Navigation/Radio/Bluetooth Display would not work. Depending on how hot the car is due to outside weather, different components stops working. Initially Rear camera/Radio/Navigation/Bluetooth all or some won't work but now only Bluetooth and Navigation doesn't work. As the car cools down overnight in the Garage, in the morning everything works just fine. During the day when car is parked outside without any shade, Bluetooth/Navigation doesn't work. Phone doesn't connect to car Bluetooth and moreover clicking on Bluetooth/Navigation button doesn't do anything. Anyone have any advice? Dealer is asking to change the display and quoting $1200.
    49,485
    electronics can be affected by heat. we used to air condition our computer room
  3. 4est
    4est Active Member
    207
    121
    Romania
    2013 Prius Plug-in
    Excel
    Install a fan inside HU. Might buy you some more time
  4. wheezyglider
    wheezyglider Active Member
    247
    178
    SF Bay Area
    If it was me and I was willing to risk damaging it, I'd open it up. If you're lucky there's a fan that is clogged or dead. Another cheap and easy fix is a heatsink over a hot chip where the grease or foam that conducts heat between them has dried out. Unscrew it and put new thermal grease. I've rescued old electronics that way.
    Anything beyond that is a good excuse to replace it with something better and cheaper, with CarPlay and AndroidWhatever. Wouldn't pay $1200 for the OEM unit in 2019.
