Bluetooth Phone & Navigation Troubleshooting
Discussion in 'Gen 4 Prius Audio and Electronics' started by JMFB, Mar 14, 2016.
  1. JMFB
    JMFB New Member
    22
    KC
    Four Touring
    When I have a my phone connected via Bluetooth and am currently using the navigation and a call comes in, the map screen is replaced with a call screen. Is there a way to take the call on Bluetooth and still have my map/ route directions not interrupted?
  2. glennonrp
    glennonrp Active Member
    178
    199
    Fontana, CA
    Four Touring
    Go into settings and and have it use a drop down instead.
    JMFB likes this.
  3. JMFB
    JMFB New Member
    22
    KC
    Four Touring
    Thank you!! Do you know how to get the navigation to stop speaking when I am on a bluetooth call?
  4. glennonrp
    178
    199
    Fontana, CA
    Four Touring
    Best I can find is to turn down, or turn off, voice guidance when you get a call or know you will be taking one. Under voice settings you can do that. I can't find any way to select it to turn off voice guidance only when taking a call.
    2. VOICE SETTINGS
    1 Press the “APPS” button.
    2 Select “Setup”.
    3 Select “Voice”.
    4 Select the items to be set.
    Voice volume, etc., can be set.
