Bluetooth Problem
Discussion in 'Gen 2 Prius Audio and Electronics' started by Ram0na, May 17, 2006.
  1. Ram0na
    Ram0na Junior Member
    Huntsville, AL
    2018 Prius Prime
    I got my Pruis April 29th and was able to connect my Treo 650 that evening to the bluetooth. But then last Friday (May 12th), it wasn't connecting. So I cleared the phone and tried to reconnect and it won't. I know the bluetooth on my phone is working because it will connect to my bluetooth earpiece.
    Any ideas? :(
  2. berylrb
    berylrb Member
    308
    san francisco?
    assuming everything is turned on still, hehehe, you may need to select the device in your 650 or erase the device in your Prius, especially if you started over and gave the setup a different name.
    I just had a heck of a time simply sending a photo from my phone to my TX via bluetooth, after getting out of the car pairing and it took like four tries. Just to say goofy stuff happens!
    b
  3. Ram0na
    Huntsville, AL
    2018 Prius Prime
    <div class='quotetop'>QUOTE(berylrb @ May 17 2006, 10:19 AM) [snapback]256863[/snapback]</div>
    I've also cleared my phone. It didn't help. :(
  4. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    <div class='quotetop'>QUOTE(Ramona @ May 17 2006, 09:03 AM) [snapback]256828[/snapback]</div>
    1. Start all over again.
    2. Use the make a call trick after the phone finds the car and while the car says it is looking for the phone.
    3. Once you have a good connection again (i.e., can make calls through the car), completely turn off the car and then start it up again.
    I'm assumimg you've installed the latest firmware upgrades on the phone.
  5. Ram0na
    Huntsville, AL
    2018 Prius Prime
    <div class='quotetop'>QUOTE(ggood @ May 17 2006, 05:41 PM) [snapback]257189[/snapback]</div>
    thanks! The Make a Call Trick worked. But sometimes it still comes up and tells me to check the phone. :(
  6. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    <div class='quotetop'>QUOTE(Ramona @ May 24 2006, 03:47 PM) [snapback]260519[/snapback]</div>
    Sometimes the magic works, and sometimes it doesn't... :D
