Bluetooth Question - AT&T Tilt
Discussion in 'Gen 2 Prius Audio and Electronics' started by RicSweeney, Jan 13, 2008.
  1. RicSweeney
    RicSweeney New Member
    Cincinnati
    I have a 2008 Prius (with Package #6 which includes Navigation, etc.), and have successfully paired my AT&T Tilt with the system.
    My question is this: I don't know how to continue a phone call after turning off my car. Right now, the phone continues the call, but I cannot hear anything and the caller on the other side cannot hear me. Obviously, it's simply a setting I need to change, but AT&T isn't of much help. Does anyone have an AT&T Tilt they have used successfully with the Hands Free bluetooth in a Prius?
    Thanks!
  2. blazer_5154
    blazer_5154 Heh, you said "member"
    106
    Maryland
    Same phone, almost same car (mine's a package #5, didn't need leather). There are a couple of different ways you can do what you need. From the MFD you can touch "transfer call" just above the "on hook" icon to continue the call on the phone. I also believe that you can click "menu" on the phone itself and select "turn off handsfree" to continue the call on the phone.
  3. RicSweeney
    Cincinnati
    Thanks, Blazer! The "Transfer" option works perfectly. It works both entering the car and leaving the car.
    :D
  4. blazer_5154
    106
    Maryland
    Glad to help, BTW, have you tried Yahoo! go or Google Maps on your tilt? Both give you use of the built-in GPS without paying for AT&T's service as long as you have a good data plan. They both also have a lot of great features like traffic data & directions. I would highly recommend either / both.
