Bluetooth RZAR Cingular Display
Discussion in 'Gen 2 Prius Audio and Electronics' started by hadman, Jun 7, 2007.
  1. hadman
    hadman New Member
    Paired the phone without issue, but the battery meter does not work and there is no caller-id. Anyone found a workaround for this?
    hadman
  2. chinalfr2
    chinalfr2 Member
    234
    New England
    <div class='quotetop'>QUOTE(hadman @ Jun 7 2007, 08:32 PM) [snapback]457701[/snapback]</div>
    Do you know where to post this question? You seem to be lost. :lol:
    Check out the Audio and Electronics Section
  3. Vagabond
    Vagabond Active Member
    1,198
    Southern California
    <div class='quotetop'>QUOTE(hadman @ Jun 7 2007, 05:32 PM) [snapback]457701[/snapback]</div>
    The battery meter/signal strength not working is typical - but when someone calls you does a phone number at least appear? Also, what version Razr do you have?
  4. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    <div class='quotetop'>QUOTE(Vagabond @ Jun 8 2007, 09:12 AM) [snapback]458055[/snapback]</div>
    Keep in mind that the number will display only when the car in not in motion.
  5. aaf709
    3,862
    2022 Prius Prime
    I have a Verizon e815 and I only see caller ID when the number is in the Prius' phonebook. Would that be different with other phones/providers?
  6. Vagabond
    1,198
    Southern California
    <div class='quotetop'>QUOTE(IsrAmeriPrius @ Jun 8 2007, 02:52 PM) [snapback]458309[/snapback]</div>
    Not on mine. I always get the name and number.
    <div class='quotetop'>QUOTE(aaf709 @ Jun 8 2007, 04:14 PM) [snapback]458341[/snapback]</div>
    Yep. I'm currently running a Motorola Q on Sprint. Fully functional in the car, from caller ID to signal strength, etc. Only took me 4 phones to find one that worked on Sprint.
  7. IsrAmeriPrius
    4,333
    Southern California
    <div class='quotetop'>QUOTE(Vagabond @ Jun 8 2007, 06:03 PM) [snapback]458390[/snapback]</div>
    Did you make any modifications for that to happen, such as cutting wires or installing a Lock Pick?
  8. Vagabond
    1,198
    Southern California
    <div class='quotetop'>QUOTE(IsrAmeriPrius @ Jun 8 2007, 06:20 PM) [snapback]458403[/snapback]</div>
    Nope. Perhaps it's somehow phone related. Not that I can see how.
  9. jem2002
    jem2002 New Member
    I also have a Cingular/ATT RAZR, and a 2007 Prius. Generally works OK, but I am getting a double "generic" ring from incoming calls thru the Prius Bluetooth/speakers. Also, the steering wheel "off-hook" button doesn't answer a call . . .I must hit the green off-hook symbol on screen to answer. What might be casuing these issues? Thank you.
  10. Vagabond
    1,198
    Southern California
    <div class='quotetop'>QUOTE(jem2002 @ Jun 10 2007, 10:20 AM) [snapback]459194[/snapback]</div>
    I'd take that to a dealer and get the button replaced under warranty.
