Bluetooth & USB audio no longer working, and cannot find an update file (Prius V 2012)
Discussion in 'Prius v Audio and Electronics' started by MaxSolar0713, Jun 9, 2023.
  1. MaxSolar0713
    MaxSolar0713 New Member
    Arizona
    Good evening, whosoever,
    About a year ago, I was plugging in a USB drive to listen to the audio files on it when abruptly the USB audio function and Bluetooth audio function ceased to work. Although I can connect my telephone (iPhone SE 2020) to the system and make/receive calls, I cannot play any music whatsoever though Bluetooth or USB. The USB port still supplies power, and the AM, FM, AUX and CD/MP3 functions still work perfectly. How can I remedy this problem? I have looked around the internet, but have found no conclusions except to "update the software."
    (Yes, I reseated the battery. No change.)
    When I attempted to find the update, I couldn't find a software file to download on the Toyota site nor anywhere else. If updating is the answer, could someone direct me to a link to download it?
    Thank you.
    Details:
    Prius V, 2012
    Deck M/N: 57011
    System Version: 5.2.0
  2. rjparker
    rjparker Tu Humilde Sirviente
    11,072
    6,937
    Texas Hill Country
    The bottom module on the 57011 has been known to go bad. Buy the whole thing.
    Isaac Zachary likes this.
  3. MaxSolar0713
    Arizona
    Dang. Well, thanks for the reply. I’ll see what I can do.
  4. Air_Boss
    Air_Boss Senior Member
    4,256
    1,195
    New Yawk
    Replaced the YY050 below the 57011, got APPS, MAPS, and Bluetooth back, but the USB port is still INOP.
  5. Air_Boss
    4,256
    1,195
    New Yawk
    Anyone know whether the TOYOTA Prius V AUX USB INPUT PORT P/N 86190-48030 installed in the lower front console has an integral fuse or fusible link?
  6. Rodney Gates
    Rodney Gates Junior Member
    This happened to me recently as well on my 2012 Prius V - Bluetooth and USB Aux port worked fine one day, then were dead the next. Not sure if it was an iPhone OS update or hardware failure (?). What is the best solution for getting the USB Aux port to work again? Should I bring it into the Toyota dealership (I'm about to gift this car to my daughter and want it all working right)?
  7. Air_Boss
    4,256
    1,195
    New Yawk
    As noted above, Replaced the YY050 extension box below the 57011, got APPS, MAPS, and Bluetooth back, but the USB port is still INOP.
    Rodney Gates likes this.
  8. Rodney Gates
    That's a shame - really want that USB port to work again.
  9. Isaac Zachary
    Isaac Zachary Senior Member
    2,779
    1,501
    I noticed this and just wanted to add I have the same problem on my 2013 Avalon hybrid. I think this is the best info I've found for fixing this as I've tried looking everywhere for a solution. The Avalon was fixed once at a dealer, but it has done it again.
